Where can I find User logs ? [SOLVED]
But when I log as a user, where can I find the logs ?
For example, the user is the user of a specific domain, he failed to connect using the FTP, so he went to his panel but didn't find any log to help him.
Is there a way to enable a user to have his logs ?
Re: Where can I find User logs ?
You will see a directory called "logs".
Click it to enter directory.
There the user can check access.log and error.log for their domains.
Re: Where can I find User logs ? [SOLVED]
The other logs (FTP or mail) are not accessible for users.
