[SOLVED] How to install Adminer ?  [SOLVED]
chaiavi
Post by chaiavi »
I see there is an option of using Adminer instead of phpMyAdmin
I read about it online and I prefer adminer.
How do I install it into my Panel ?
I know where to configure the adminer url into the panel (found that one)
But how do I install the adminer into my system ?
Re: How to install Adminer ?  [SOLVED]
Adminer is part of the KeyHelp bundle and is already installed.
Inside of the KeyHelp admin area, go to "Configuration" -> "Database administration" and select "Adminer" from the drop down "Database administration client".
After a minute has passed, Adminer should be ready to use.
chaiavi
Post by chaiavi »
Ohh
Thank you
It worked exactly as you said!
