Postfix/Mysql - [SYS/TEMP] Temporary authentication failure.  [SOLVED]
benkhouya
Post by benkhouya »
After a successful installation of KeyHelp on Ubuntu 18 (64bits), I have the following problem:
I can't authenticate via an email client to retrieve my emails, with Gmail I get the error "[SYS/TEMP] Temporary authentication failure" and at the server level I have the following error : Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
Here is a preview of /var/log/mail.log
root@vps:~# tail -f /var/log/mail.log
May  8 09:56:52 vps dovecot: auth-worker(17960): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 125 seconds before retry
May  8 09:57:21 vps dovecot: auth: Error: auth worker: Aborted PASSV request for my@email.address: Lookup timed out
May  8 09:57:21 vps dovecot: auth-worker(17960): Error: mysql: Query timed out (no free connections for 60 secs): SELECT email AS user, password, CONCAT('*:storage=',quota) AS userdb_quota_rule FROM   mail_users WHERE  email='my@email.address' AND login_enabled = 'Y';
May  8 09:57:21 vps dovecot: auth-worker(17960): Error: sql(my@email.address,[IPADDRESS],<BnlnAiClCpnRVdAN>): Password query failed: Not connected to database
May  8 09:57:21 vps dovecot: auth-worker(17960): Warning: Auth master disconnected us while handling request for my@email.address for 60 secs (result=FAIL)
May  8 09:57:21 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
May  8 09:57:22 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 5 seconds before retry
May  8 09:57:23 vps dovecot: pop3-login: Disconnected (auth failed, 1 attempts in 62 secs): user=<my@email.address>, method=PLAIN, rip=[IPADDRESS], lip=[IPADDRESS], TLS: Disconnected, session=<BnlnAiClCpnRVdAN>
May  8 09:57:27 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 25 seconds before retry
May  8 09:57:52 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 125 seconds before retry
May  8 09:58:20 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
May  8 09:58:21 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 5 seconds before retry
May  8 09:58:26 vps dovecot: auth-worker(19064): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 25 seconds before retry
EDIT : Webmail (Roundcube) on KeyHelp also doesn't work to access emails.
Re: Postfix/Mysql - [SYS/TEMP] Temporary authentication failure.
is your mysqld running properly?
benkhouya
Post by benkhouya »
Yes, because my WordPress sites are working properly.
benkhouya
Post by benkhouya »
Isn't there a script or command from KeyHelp, to check and fix Postfix/Dovecot integration with MySQL?
That I can fix this error without having to reinstall everything.
george
Post by george »
Did you try the obvious, restart mysql and/or reboot server?
Also check /var/log/mysql/error.log for clues.
benkhouya
Post by benkhouya »
I restarted MySQL and Dovecot and Postfix, and also the VPS, without success it doesn't fix my problem.
Below the content of /var/log/mysql/error.log
root@vps:~# cat /var/log/mysql/error.log
2020-05-10 13:19:40 139786339948288 [Note] /usr/sbin/mysqld: Normal shutdown
2020-05-10 13:19:40 139786339948288 [Note] Event Scheduler: Purging the queue. 0 events
2020-05-10 13:19:41 139785641367296 [Note] InnoDB: FTS optimize thread exiting.
2020-05-10 13:19:41 139786339948288 [Note] InnoDB: Starting shutdown...
2020-05-10 13:19:41 139786339948288 [Note] InnoDB: Waiting for page_cleaner to finish flushing of buffer pool
2020-05-10 13:19:44 139786339948288 [Note] InnoDB: Shutdown completed; log sequence number 11254557
2020-05-10 13:19:44 139786339948288 [Note] /usr/sbin/mysqld: Shutdown complete
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to legacy because of small buffer pool size. In order to use backoff, increase buffer pool at least up to 20MB.
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Using mutexes to ref count buffer pool pages
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: The InnoDB memory heap is disabled
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Compressed tables use zlib 1.2.11
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Using Linux native AIO
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Using SSE crc32 instructions
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Initializing buffer pool, size = 128.0M
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Completed initialization of buffer pool
2020-05-10 13:20:04 140412671216768 [Note] InnoDB: Highest supported file format is Barracuda.
2020-05-10 13:20:05 140412671216768 [Note] InnoDB: 128 rollback segment(s) are active.
2020-05-10 13:20:05 140412671216768 [Note] InnoDB: Waiting for purge to start
2020-05-10 13:20:05 140412671216768 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.46-86.2 started; log sequence number 11254557
2020-05-10 13:20:06 140412671216768 [Note] Plugin 'FEEDBACK' is disabled.
2020-05-10 13:20:06 140411880302336 [Note] InnoDB: Dumping buffer pool(s) not yet started
2020-05-10 13:20:07 140412671216768 [Note] Server socket created on IP: '127.0.0.1'.
2020-05-10 13:20:07 140412671216768 [Note] /usr/sbin/mysqld: ready for connections.
Version: '10.1.44-MariaDB-0ubuntu0.18.04.1'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306  Ubuntu 18.04
benkhouya
Post by benkhouya »
Will the next KeyHelp update 20.1 fix my error?
Or do I have to reinstall the whole thing from scratch?
This is obviously one of the errors below:
- Dovecot not being able to connect to MySQL
- Dovecot's MySQL privileges are incorrect
- The problem lies in the creation of a mail account on the server, via the KeyHelp interface.
May 13 02:00:17 vps dovecot: lmtp(31011): Connect from local
May 13 02:00:17 vps dovecot: lmtp(31013): Connect from local
May 13 02:00:17 vps dovecot: auth-worker(31014): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
May 13 02:00:17 vps dovecot: auth-worker(31015): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
May 13 02:00:17 vps dovecot: auth: Error: auth worker: Aborted USER request for my@email.address: Internal auth worker failure
May 13 02:00:17 vps dovecot: lmtp(my@email.address): Error: user my@email.address: Auth USER lookup failed
May 13 02:00:17 vps dovecot: auth-worker(31015): Error: sql(my@email.address): User query failed: Not connected to database
May 13 02:00:17 vps dovecot: auth-worker(31016): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 1 seconds before retry
May 13 02:00:17 vps dovecot: auth: Error: auth worker: Aborted USER request for root@myhostname: Internal auth worker failure
May 13 02:00:17 vps dovecot: lda(root@myhostname): Error: user root@myhostname: Auth USER lookup failed
May 13 02:00:17 vps dovecot: lda: Fatal: Internal error occurred. Refer to server log for more information.
May 13 02:00:17 vps postfix/lmtp[31009]: 2DB4E61EC9: to=<my@email.address>, relay=myhostname[private/dovecot-lmtp], delay=431534, delays=431534/0.02/0.03/0.04, dsn=4.3.0, status=deferred (host myhostname[private/dovecot-lmtp] said: 451 4.3.0 <my@email.address> Internal error occurred. Refer to server log for more information. (in reply to RCPT TO command))
May 13 02:00:17 vps dovecot: lmtp(31013): Disconnect from local: Successful quit
May 13 02:00:17 vps dovecot: auth-worker(31016): Error: sql(root@myhostname): User query failed: Not connected to database
May 13 02:00:17 vps postfix/pipe[31010]: 91FE361E93: to=<root@myhostname>, relay=dovecot, delay=2400, delays=2400/0.01/0/0.09, dsn=4.3.0, status=deferred (temporary failure)
May 13 02:00:18 vps dovecot: auth-worker(31014): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 5 seconds before retry
May 13 02:00:23 vps dovecot: auth-worker(31014): Error: mysql(localhost): Connect failed to database (keyhelp): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (13) - waiting for 25 seconds before retry
Please help!
What does the MySQL log say at the time of the mail error?
What performance data does the server have?
benkhouya
Post by benkhouya »
There are no errors in the MySQL log, either when adding a new email address, or during authentication.
root@vps:~# tail -f /var/log/mysql/error.log
And as for performance, it's a VPS KVM with Ubuntu 18.04 (64bits), 1Gb RAM and 20Gb SSD disk space.
PS. The 20.1 update didn't solve my problem, unfortunately.
Re: Postfix/Mysql - [SYS/TEMP] Temporary authentication failure.  [SOLVED]
I have checked the problem on benkhouya's server.
Although I initially failed to get the connection working via the socket connector (and stopped the attempt after the fix below), I was able to resolve the problem by modifying the following file:
/etc/dovecot/dovecot-sql.conf
In this file you find the following line:
connect = "host=localhost dbname=keyhelp user=keyhelp password=<PASSWORD>"
I changed this to:
connect = "host=127.0.0.1 dbname=keyhelp user=keyhelp password=<PASSWORD>"
Reason why this worked: When using "localhost, the socket connector is used, when using 127.0.0.1 the TCP/IP connector is used.
benkhouya
Post by benkhouya »
Thank you very much Alexander, it's working perfectly.
One last question:
Will this modification be integrated in a fix in the next version? Or do I have to do it manually?
This file gets created during KeyHelp installation and then remains untouched.
So you don't have to do anything.
