Cronjob on panel  [SOLVED]
info@eurhosting.net
Cronjob on panel
Post by info@eurhosting.net »
At the moment the only way to create a cronjob is using SSH
Would be great to be able to have the opportunity to create them via panel.
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
Re: Cronjob on panel  [SOLVED]
i'm happy to inform you, that we will release a new version of KeyHelp tomorrow
and the cron job feature ('scheduled task', as it is called in KeyHelp) is part of it.
This update will be automatically deployed on your KeyHelp server.
info@eurhosting.net
That's great, I even saw the news, but I still can not locate it on the panel
Do you have a screenshot to where have I to look for? (I have 14.6.3 ad KH version)
Stop stop stop
info@eurhosting.net
Found it
I had to clean the whitelabel, but I really don't get why this is happening.
I'm applying a very soft js to hide some menu
$('document').ready( function () {
	var url      = window.location.href;
  	// il link whitelabel lo nascondo da tutte le pagine
  	$("div#overallwrapper div.nav ul li a:contains('White label')").closest('li').hide();
  	$("div#overallwrapper div.nav ul li a:contains('Брендирование')").closest('li').hide();
  	$("div#overallwrapper div.nav ul li a:contains('Whitelabel')").closest('li').hide();
	if (url.indexOf("admin_index") >= 0)
		// remove news
		$("div.page div.content th:contains('News')").closest('div').remove();
		$("div.page div.content th:contains('новости')").closest('div').remove();
		// rimuovo link changelog
		$("div.page div.content a:contains('See history of changes')").remove();
		$("div.page div.content a:contains('Änderungsprotokoll anzeigen')").remove();
		$("div.page div.content a:contains('История изменений')").remove();
According to this code it simply remove the news and the white label menu, but I don't have the "scheduled Task" in the user interface
Stop stop stop
You have to make sure that the user limits of 'Scheduled Tasks' is greater than 0.
After that, the 'Scheduled Task' menu item will appear in the user area of the panel.
The whitelabel settings you have in place do not interfere with the visibility of the 'Scheduled Task' menu item.
By the way, some spelling changed with KH 14.6.3, so please replace the following line:
with
$("div#overallwrapper div.nav ul li a:contains('White Label')").closest('li').hide();
*can be deleted*
*wrong language*
b0snaX
Post by b0snaX »
Tobi wrote:Ist dieses Feature auch für den User "keyadmin" geplant, so daß man im Frontend root-Cronjobs anlegen kann?
Der Übersicht zu Liebe Poste bitte dein Anliegen im Deutschen Bereich, da wir hier im Englischen Support bereich sind.
Schöne Grüße,
b0snaX
Is this feature in a future release planned for the user "keyadmin"?
I would like to manage root cronjobs in the KeyHelp webfrontend.
Sorry, I did not know there is a strict seperation.
I will remember this for further posts in this section.
