Module for WHMCS
sly2000
Module for WHMCS
Post by sly2000 »
Hello everybody! I want to use KeyPanel through the WHMCS module.
Since there is no such module on the Internet at the moment, I propose to order the development of this module by joint efforts !?
If you are interested in this offer, write to me in PM. Let's get together and make this module for WHMCS! :!: :!: :!:
Re: Module for WHMCS
At the moment there is no WHMCS-plugin planned, but of course you can look for volunteers here. It would be a perfect community project for the "Bastelecke / Modification Corner". viewforum.php?f=16
With the help of the KeyHelp API (https://app.swaggerhub.com/apis-docs/keyhelp/api/) this should be an easy task.
I wrote a WHMCS plugin a long time ago, back when the KeyHelp API didn't exist, and it was pretty straightforward, now in times when you can rely on the API it should be even easier.
You might also want to ask the WHMCS developers if they want to officially support KeyHelp, which of course would be the best choice when it comes to support for upcoming WHMCS versions.
info@eurhosting.net
Post by info@eurhosting.net »
Actually I asked to WHMCS Global Services if they are considering to develop one.
If you want to join the request simply open a tickt with them here: https://whmcsglobalservices.com/members ... 2&deptid=5
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
