Error While installing on Ubuntu Server 20.04 [SOLVED]
I executed the installation command on a freshly installed Ubuntu 20.04
And it stops right here:
Failed loading /usr/local/ioncube/ioncube_loaders_lin64_7.4_10.4.0_beta6.so: /usr/local/ioncube/ioncube_loaders_lin64_7.4_10.4.0_beta6.so: cannot open shared object file: No such file or directory
PHP Parse error: syntax error, unexpected 'ionCube' (T_STRING) in /home/keyhelp/www/keyhelp/install/install.php on line 5
inside my /usr/local/ioncube/ I find ioncube_loaders_lin64_7.4_10.4.0_beta7.so not ioncube_loaders_lin64_7.4_10.4.0_beta6.so
maybe the installer script should be updated?
Thank you very much indeed
[Mod-Edit]
Thread moved to english section.
Reason: Mod-Edit
Re: Error While installing on Ubuntu Server 20.04
inside install_keyhelp.sh sometimes you refer to ioncube_loader and sometimes to ioncube_loaders
just fix it
mkdir -p /usr/local/ioncube
local downloadUrl="https://install.keyhelp.de/misc/ioncube_loader_lin64_7.4_10.4.0_beta7.so"
wget --prefer-family="$PREFERRED_PROTOCOL" --quiet --show-progress --output-document /usr/local/ioncube/ioncube_loader_lin64_7.4_10.4.0_beta7.so $downloadUrl
local soFile="/usr/local/ioncube/ioncube_loaders_lin64_7.4_10.4.0_beta6.so"
local downloadUrl="http://downloads3.ioncube.com/loader_downloads/ioncube_loaders_lin_x86-64.tar.gz"
local soFile="$extractTo/ioncube/ioncube_loader_lin_`get_php_version`.so"
local soFile="$extractTo/ioncube/ioncube_loader_lin_`get_php_version`.so"Sometimes you call ioncube_loader and sometimes ioncube_loaders
The script works fine with Ubuntu 18.04.
Please be patient. I'm just a moderator, not a developer. I think the best way is to wait for an answer from the head developer.
Have a nice night
Re: Error While installing on Ubuntu Server 20.04 [SOLVED]
Installing KeyHelp on Ubuntu 20 is not open for public and it is nothing one should do at this stage.
You should have seen the following note, when trying to install KeyHelp on Ubuntu 20
The support for Ubuntu 20 is currently in closed BETA state.For the sake of simplicity, I have included the routines for installing on Ubuntu 20 in the regular install_keyhelp.sh, but as I see now, people try to use them, even if they read the note, I probably have to remove them.
