Migrating Postfix mailboxes from old server  [SOLVED]
martins
Post by martins »
Hello guys,
Does anyone know the basic concept of postfix mailbox migration to KeyHelp Panel?
What should I do to perform the migration?
Thank you!
*sorry for my English
Re: Migrating Postfix mailboxes from old server  [SOLVED]
the best way is a use of a tool like IMAPcopy
Just create the imapcopy configuration with the login data of the old and the corresponding new mailbox and start it.
It will copy all mails and folders
