Does KeyHelp Update disable cron jobs?
george
Post by george »
I have some heavy cron jobs and was wondering...
Does the coming KeyHelp 20.2 update disable cron jobs before it runs?
If no, I will just disable some crons (temporarily).
I'm interested to know.
Re: Does KeyHelp Update disable cron jobs?
The update to 20.2 has no effect on cron jobs, running cron jobs or those that are started during the update process.
As long as the cronjob does not perform any changes in the /home/keyhelp/ folder or the `keyhelp` database, everything is fine.
Happy updating ;)
george
Post by george »
Thankyou Alexander, I thought so. I have already disabled those that may be problematic.
I guess the update can be triggered manually by the "Update administration panel" cron in "Maintenance Intervals".
OR
is it best left on auto?
You can trigger the update manually.
No problem.
I install every update manually.
george
Post by george »
Excellent! Looking forward to it... :)
