Disk Space Usage by folder [SOLVED]
Currently, I go to ssh and use ncdu which is a great tool.
It would be much more convenient if it was integrated in KH.
I used it alot when I had cPanel (https://www.liquidweb.com/kb/how-to-use ... in-cpanel/)
Re: Disk Space Usage by folder
I think i could finish something today, which should fit your needs. I'll report back as soon as I have something to show.
Re: Disk Space Usage by folder [SOLVED]
- Reseller4711
Danke
