I'm trying to install Sphinx search on my server and open the port in the firewall, but if I run netstat for the port, it returns nothing, so the port isn't open and the program doesn't work.
Sphinx search [SOLVED]
Sphinx search
Re: Sphinx search [SOLVED]
then the service is not running.
