Scheduled Tasks and Backup endpoints in API  [SOLVED]
nisompic
Post by nisompic »
I'm currently using KeyHelp's API to expose some of its functionality to my users.
Scheduled tasks have been included in KeyHelp for quite some time now, but as far as I can see, there's no way to interact them outside of KeyHelp's panel directly.
Is implementing an endpoint for scheduled tasks in the roadmap for KeyHelp?
EDIT: I've not found any way to trigger backups from the API either, is that possible too?
Regards
Re: Scheduled Tasks and Backup endpoints in API  [SOLVED]
You are right, there is currently no API endpoint for scheduled tasks. I have incresed the priority on the todo list a bit - expect this feature with one of the upcoming releases.
Considering an endpoint for triggering backups will have to wait until the new backup system will be ready, which will be one of the next bigger projects after the next release.
nisompic
Post by nisompic »
Thank you for the update, glad you could push the feature higher!
I'm looking forward to next releases as they sure seem very feature-rich and interesting!
Thanks for your work!
Enigma
Post by Enigma »
Great, I'm also interested in this feature!
Cheers,
Jan
