Amavis stirbt alle 2 Wochen
bytegetter
Post by bytegetter »
Früher nur alle paar Monate ist Amavis nun bereits nach 1.5 Wochen gestorben. Das fällt mir immer daran auf, dass ich keine eMails mehr erhalte.
Sep 25 06:01:26 admin3 amavis[11231]: (11231-09) Passed CLEAN {RelayedInbound}, [79.140.117.252]:8609 [79.140.117.252] <nas@xxxxx.de> -> <admin@xxxxx.de>, Queue-ID: 843AAFF117, mail_id: 7ytTkma3b7ij, Hits: -2.293, size: 1214, queued_as: 838A2FF296, 64700 ms
Sep 25 06:01:26 admin3 amavis[11852]: (11852-01) Passed CLEAN {RelayedInbound}, [79.140.117.252]:7755 [79.140.117.252] <nas@xxxxx.de> -> <admin@xxxxx.de>, Queue-ID: B4672FF138, mail_id: MWDLEIP8Vs3C, Hits: -2.293, size: 1214, queued_as: 84F39FF2C8, 64640 ms
Sep 25 06:01:26 admin3 amavis[11231]: (11231-09) (!!)TROUBLE in check_mail, but must continue (1): update_snmp FAILED: update_snmp_variables: BDB S db_cursor: BDB0061 PANIC: Invalid argument, . at (eval 94) line 107.
Sep 25 06:01:26 admin3 amavis[11852]: (11852-01) (!!)TROUBLE in check_mail, but must continue (1): update_snmp FAILED: update_snmp_variables: BDB S c_put: BDB0060 PANIC: fatal region error detected; run recovery, . at (eval 94) line 147.
Sep 25 06:01:26 admin3 amavis[11852]: (11852-01) (!!)TROUBLE in process_request: register_proc: BDB N db_cursor: BDB0060 PANIC: fatal region error detected; run recovery, . at (eval 94) line 220.
Sep 25 06:01:26 admin3 amavis[11852]: (11852-01) (!)Requesting process rundown after fatal error
Sep 25 06:01:26 admin3 amavis[11231]: (11231-09) (!!)TROUBLE in process_request: register_proc: BDB N db_cursor: BDB0060 PANIC: fatal region error detected; run recovery, . at (eval 94) line 220.
Sep 25 06:01:26 admin3 amavis[11231]: (11231-09) (!)Requesting process rundown after fatal error
Sep 25 06:01:26 admin3 postfix/smtp[12056]: 843AAFF117: to=<admin@xxxxx.de>, orig_to=<nas@xxxxx.de>, relay=127.0.0.1[127.0.0.1]:10024, delay=65, delays=0.25/0.15/0/65, dsn=4.3.2, status=deferred (host 127.0.0.1[127.0.0.1] said: 421 4.3.2 Service shutting down, closing channel (in reply to end of DATA command))
Sep 25 06:01:26 admin3 postfix/smtp[12057]: B4672FF138: to=<admin@xxxxx.de>, orig_to=<nas@xxxxx.de>, relay=127.0.0.1[127.0.0.1]:10024, delay=65, delays=0.32/0.02/0.01/65, dsn=4.3.2, status=deferred (host 127.0.0.1[127.0.0.1] said: 421 4.3.2 Service shuttin
Sep 25 06:01:26 admin3 amavis[11231]: (11231-09) (!)TempDir removal: tempdir is to be PRESERVED: /var/lib/amavis/tmp/amavis-20200925T054731-11231-DhKEF2dT
Sep 25 06:01:26 admin3 amavis[11852]: (11852-01) (!)TempDir removal: tempdir is to be PRESERVED: /var/lib/amavis/tmp/amavis-20200925T060021-11852-UJQOMk8M
Sep 25 06:01:27 admin3 amavis[11852]: (11852-01) (!)_DIE: register_proc: BDB N db_cursor: BDB0060 PANIC: fatal region error detected; run recovery, . at (eval 94) line 220.
Sep 25 06:01:27 admin3 amavis[11852]: (11852-01) (!)Amavis::END: DB unregistering failed:
Sep 25 06:01:27 admin3 amavis[11231]: (11231-09) (!)_DIE: register_proc: BDB N db_cursor: BDB0060 PANIC: fatal region error detected; run recovery, . at (eval 94) line 220.
Sep 25 06:01:27 admin3 amavis[11231]: (11231-09) (!)Amavis::END: DB unregistering failed:
Sep 25 06:01:27 admin3 postfix/smtpd[12102]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=1 data=1 commands=4
Sep 25 06:01:27 admin3 amavis[12110]: (!!)TROUBLE in child_init_hook: BDB can't connect db env. at /var/lib/amavis/db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery, No such file or directory. at (eval 94) line 338.
Sep 25 06:01:27 admin3 amavis[12110]: (!)_DIE: Suicide in child_init_hook: BDB can't connect db env. at /var/lib/amavis/db: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery, No such file or directory. at (eval 94) line 338.
Platz sollte auf der VM mehr als genug sein:
root@admin3:/var/log# df -h
Dateisystem                 Größe Benutzt Verf. Verw% Eingehängt auf
udev                         2,0G       0  2,0G    0% /dev
tmpfs                        395M     21M  375M    6% /run
/dev/mapper/admin3--vg-root   28G     11G   16G   42% /
tmpfs                        2,0G       0  2,0G    0% /dev/shm
tmpfs                        5,0M       0  5,0M    0% /run/lock
tmpfs                        2,0G       0  2,0G    0% /sys/fs/cgroup
/dev/sda1                    236M     84M  140M   38% /boot
tmpfs                        395M       0  395M    0% /run/user/0
root@admin3:/var/log# free -h
              total        used        free      shared  buff/cache   available
Mem:          3,9Gi       2,3Gi       309Mi        26Mi       1,3Gi       1,3Gi
Swap:         4,0Gi       5,0Mi       4,0Gi
Wie bekomme ich heraus, was da nicht passt?
Bytegetter
andromeda
Re: Amavis stirbt alle 2 Wochen
Post by andromeda »
Irgendein Problem mit der Amavis db. Da es nur sehr sporadisch ist... kannst den Dienst per monit überwachen und dann automatisch neu starten lassen.
Sieht für mich nach ner zerschossenen Datenbank aus ... :?
Die VM mal öffters unsauber abgeschaltet (?)
Du könntest folgendes probieren:
Amavis stoppen, Inhalt von /var/lib/amavis/db sichern, den Inhalt des Ordners löschen und Amavis wieder starten.
Dann wird die DB in 99% sauber neu angelegt.
Schlimmstenfalls einmal Server reboot aber eig. nicht nötig.
Wenn es nen DB defekt ist, wovon ich ausgehe, sollte das Thema damit vom Tisch sein. :idea:
