Change home folder for a domain  [SOLVED]
kurgans
Post by kurgans »
Good morning to all
First I apologize to everyone for my bad English, since I only speak Spanish and I use a translator that I don't really know how to interpret my words.
Second to thank this community for their work, which I am testing .. and I have really felt quite comfortable and friendly with its use.
It has been and is a good experience .. Thank you all, for those who develop, contribute and use to keep this project alive
Although everything is quite friendly .. I have been looking for the option of being able to load a project in Laravel and to be able to define the home / users / www / public folder as the starting system of my application
I have not been able to find how to do this ... some of you can help me a little to do it
Thank you very much to all
nikko
Re: Change home folder for a domain
Post by nikko »
You can use the domain-settings to point the domain to your favorite destination-directory.
kurgans
Post by kurgans »
Good afternoon everyone
Thank you for your interest in my problem to be able to help me, I think I have not managed to explain myself well .. or I do not see the option that you recommend
I can put the mount point of my domain as in any favorite folder as you have indicated, but my main problem is not the mount point to put myproject.tld files.
What is not really located is the way in my folder structure to indicate which folder is the root to start my web project
As you can see in my apache configuration .. I can't find an option to change this parameter from the same panel
Example
# www.myproyecto.tld
<VirtualHost *: 443>
ServerName www.myproyecto.tld
ServerAdmin followings@myproject.tld
DocumentRoot "/ home / users / myproject / www /" -> Change this to DocumentRoot "/ home / users / myproject / www / public"
SuexecUserGroup "project" "project"
Thank you very much for your everything
Re: Change home folder for a domain  [SOLVED]
What nikko wants to say is: To change the document root of a domain, just open the domain management, than click on the pen icon of a desired domain. Than a new editing window with all options for this particular domain will open. Here you can change the document root for this domain.
I have made a screenshot for you, to make it more clearer. The image shows the screen, when adding a new domain, but the options are the same, no matter if creating or editing a domain.
To stick with your example, just put "public" into the input box, marked with "2." (on the screnshot)
kurgans
Post by kurgans »
Hello good day
Ahh, perfect they had not understood the use correctly, my translator did not interpret the message of the colleague correctly ...
I'm really sorry for the mistake ...
Now if .. I have seen its function and the change in our apache file.
Thank you very much for your help
S2
You are welcome ;).
By the way, i can recommend https://www.deepl.com/translator for translating texts.
I experienced much better results than google translate etc.
kurgans
Post by kurgans »
Okay, thanks for everything, I will follow your advice,
Greetings
