Error While installing on Ubuntu Server 20.04  [SOLVED]
Tony20
Post by Tony20 »
Installing on a Dedicated Server, Ubuntu 20.04 OS.
I got this error.
Installation is running:
Update sources list ... [OKAY]
Installation requirements ... [OKAY]
Hostname ... [OKAY]
Sudo ... [OKAY]
Bind9 ... [OKAY]
SSL/TLS ... [OKAY]
PHP ... [OKAY]
Apache web server ... [OKAY]
PHP-FPM ... [OKAY]
MariaDB ... [OKAY]
KeyHelp ... [OKAY]
Firewall ...
Warning: file_put_contents(/etc/network/if-pre-up.d/keyhelp_load_rules): failed to open stream: No such file or directory in /home/keyhelp/www/keyhelp/core/pending/File.php on line 341
[ERROR]
Errors occurred during installation!
Tony.
Re: Error While installing on Ubuntu Server 20.04
can you please create the directory
in advance by yourself, and than run the installation again. Than it should run fine.
(This will be fixed with the next release)
Tony20
Re: Error While installing on Ubuntu Server 20.04  [SOLVED]
Post by Tony20 »
Alexander, Thank you very much!
Tony20
Post by Tony20 »
Alexander wrote: Thu 26. Nov 2020, 09:17 Hello,
What permissions this directory need?
It should be owned by root with 0755.
Tony20
Post by Tony20 »
Alexander wrote: Thu 26. Nov 2020, 16:49 It should be owned by root with 0755.
