keyhelp and php/apache directive
info@eurhosting.net
Post by info@eurhosting.net »
Hello team
Is there any php/apache directive that cut the apache response after a certain usage like maxconnection?
Asking because we have performed a load test on a RVS S14 and after 150 user no one was able to navigate the website even is the load on the server was more than normal between 24 and 25.
Any clue?
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
Re: keyhelp and php/apache directive
check the Error Log of the Webserver /var/log/apache2/error.log if the server reaches MaxRequestWorkers limit
select name from me;
info@eurhosting.net wrote: Wed 6. Jan 2021, 12:39 ... even is the load on the server was more than normal between 24 and 25.
I think this load is pretty high.
info@eurhosting.net wrote: Wed 6. Jan 2021, 12:39 Is there any php/apache directive that cut the apache response after a certain usage like maxconnection?
Use this command on the shell:
apache2ctl status
If you see a lot of RRRRRR..., the processes are probably stuck on read.
We had this problem due to massiv access from a bot via https://IP.of.the.server.
The solution was to block the bot on the firewall.
Viele Grüße, Christian
