Fail2ban not banning IPs
Tony20
Post by Tony20 »
Does Fail2ban needs to be config to work Keyhelp?
looking sudo fail2ban-client status sshd it show no banned IPs.
Do I have to edit the /etc/fail2ban/jail.conf for it to work? or I don't need to edit anything?
I changed my ssh default port 22 .. could that be the reason is not banning IPs?
Tony.
andromeda
Re: Fail2ban not banning IPs
Post by andromeda »
You may try to adjust the port in jail.conf
Tony20
Post by Tony20 »
andromeda wrote: Wed 6. Jan 2021, 15:18 You may try to adjust the port in jail.conf
I read that jail.conf get overwritten with updates. it say on top "You should not modify this file"
I think keyhelp use a different file. to conf fail2ban.
I try creating the jail.local but it didn't work got this error.
ERROR Failed to access socket path: /var/run/fail2ban/ fail2ban.sock. Is fail2ban running?
I am using Ubuntu 20.04.
andromeda
Post by andromeda »
Tony20 wrote: Wed 6. Jan 2021, 16:13
I read that jail.conf get override with updates.
maybe there is some kind of misconfiguration.
demo@demo:/etc/fail2ban/jail.d$ ls
defaults-debian.conf
keyhelp.local
