Installations-Fehler  [GELÖST]
jskiweb
Post by jskiweb »
Hallo Libe Community ich habe folgenden Fehler erhalten, habe die firewall getestet und leider funktioniert sie wirlich komplett nicht. Leider würde ich sie gerne nutzen. Vielen Dank im Vorraus
Firewall
exec | mkdir -p -m 0700 /etc/keyhelp/iptables/
exec | chown keyhelp:keyhelp -R /etc/keyhelp/iptables/
exec | apt-get install -y nftables
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libnftables1
Suggested packages:
firewalld
The following NEW packages will be installed:
libnftables1 nftables
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 280 kB of archives.
After this operation, 887 kB of additional disk space will be used.
Get:1 http://asi-fs-n.contabo.net/ubuntu focal/universe amd64 libnftables1 amd64 0.9.3-2 [229 kB]
Get:2 http://asi-fs-n.contabo.net/ubuntu focal/universe amd64 nftables amd64 0.9.3-2 [51.2 kB]
Fetched 280 kB in 0s (16.7 MB/s)
Selecting previously unselected package libnftables1:amd64.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 71336 files and directories currently installed.)
Preparing to unpack .../libnftables1_0.9.3-2_amd64.deb ...
Unpacking libnftables1:amd64 (0.9.3-2) ...
Selecting previously unselected package nftables.
Preparing to unpack .../nftables_0.9.3-2_amd64.deb ...
Unpacking nftables (0.9.3-2) ...
Setting up libnftables1:amd64 (0.9.3-2) ...
Setting up nftables (0.9.3-2) ...
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for libc-bin (2.31-0ubuntu9.1) ...
exec | mkdir -p -m 0755 /etc/nftables/
files | firewall/rules/rules_ipv4_common => /etc/keyhelp/iptables/startup_rules_ipv4
files | firewall/rules/rules_ipv6_common => /etc/keyhelp/iptables/startup_rules_ipv6
files | firewall/keyhelp_load_rules => /etc/network/if-pre-up.d/keyhelp_load_rules
Could not save file "/etc/network/if-pre-up.d/keyhelp_load_rules"
[SKIPPED DUE PREVIOUS ERRORS] files | firewall/keyhelp-load-firewall-on-startup.service => /etc/systemd/system/keyhelp-load-firewall-on-startup.service
[SKIPPED DUE PREVIOUS ERRORS] files | nftables/nftables.conf => /etc/nftables.conf
[SKIPPED DUE PREVIOUS ERRORS] files | nftables/fail2ban.conf => /etc/nftables/fail2ban.conf
[SKIPPED DUE PREVIOUS ERRORS] exec | chmod 0755 /etc/network/if-pre-up.d/keyhelp_load_rules
[SKIPPED DUE PREVIOUS ERRORS] exec | chown keyhelp:keyhelp /etc/keyhelp/iptables/*
[SKIPPED DUE PREVIOUS ERRORS] exec | systemctl enable keyhelp-load-firewall-on-startup.service
[SKIPPED DUE PREVIOUS ERRORS] exec | nft -f /etc/nftables/fail2ban.conf
[SKIPPED DUE PREVIOUS ERRORS] import | /home/keyhelp/www/keyhelp/install/templates/firewall/rules/default_common.sql => keyhelp
[SKIPPED DUE PREVIOUS ERRORS] import | /home/keyhelp/www/keyhelp/install/templates/firewall/rules/active_common.sql => keyhelp
Re: Installations-Fehler  [GELÖST]
