enable SSL subdomains
tom83
Post by tom83 »
When I try to access webmail.domain.com it shows "insecure".
Also how can I enable SSL (Let's Encrypt) for subdomains like: webmail.domain.com and mail.domain.com ?
Outlook always shows insecure connection too. What are all steps to make this work?
Thanks.
Re: enable SSL subdomains
you can configure the SSL certificates for Webmail and the mailserver under SSL-certiicates -> Secure server services
tom83
Post by tom83 »
I am using CloudFlare. Then seems that SSL is not working. Do you know the steps to make it work?
you can configure the SSL traffic in the backend of cloudflare. For more information you must contact their support.
tom83
Post by tom83 »
Yes. Thanks.
I know how to make SSL work in CloudFlare. I would need to make it work on both KeyHelp and CloudFlare, if is possibble.
I can't enable the orange cloud (proxy) in CloudFlare for "mail.domain.com" because would hide the IP address then isn't possible to use this configuration on Outlook.
at the moment Keyhelp can only use the Let's encrypt certificate of the servername or any other uploaded certificate from a different CA
So either you name your server mail.domain.com or you buy a certificate for this domain, upload it to Keyhelp and activate it as cert for the mailserver.
