User ssl sert
Drema
User ssl sert
Post by Drema »
User can upload ssl sert for his domain and use it?
And In Email address page user control panel, has a text: "If available, you can use, your own SSL protected domain as well.» How to do it?
Thanks!
Daniel
Re: User ssl sert
Post by Daniel »
Privet Drema,
currently its not possible for domainadmins/domainusers to manage SSL-certificates. Up till now its just possible to configure them using the "keyadmin" or any other privileged useraccount @ "Security/SSL Certificates".
But we are able to confirm that within' the next Keyhelp update the management of SSL-certificates is possible for normal domainadmins/domainusers. With an additional function to lock/unlock this feature for these users as "keyadmin".
A guide how to set up and configure SSL-certificates is provided at our administrator manual (already linked @ Keyhelp) -> direct link: https://goo.gl/IWjGj7. The mentioned guide about configuration of SSL-certificates is described at "7.1. SSL Certificates" (p.40).
Daniel Marckardt
