Same user for different databases... ?
kurgans
Post by kurgans »
Good morning to all.
Sorry for my English, I only speak Spanish ...
I wanted to ask ... if we can assign by the panel the same user several databases, so that they can adminstrar all of the same user.
Thanks
Re: Same user for different databases... ?
a single KeyHelp user account can own and manage multiple databases.
But each of the databases will have its own database user with own database login credentials.
(This will help separating various applications/projects from each other, each with their own login credentials)
kurgans
Post by kurgans »
Thank you if I understand what you mean ....
...but it would be nice to be able to include to be able to select a user created to a new database to be able to manage by phpmyadmin..., at user level and its assigned databases.
... it would be nice to be able to include more than one user to the databases to manage a remote connection and another local connection.
The databases are still different projects, but it would be more comfortable to be able to access these data and define their use by having more than one user.
Thanks
