Remote backup problems  [SOLVED]
Amadex
Post by Amadex »
Hello, I've setup yesterday a remote backup to a server that I don't use so I can use that storage at least.
My keyhelp panel version is: 20.3.2 (Build 2131)
Now the problem is:
I have entered remote backup details (ip, port, sftp, password) and tested the connection, it works.
When I create a manual backup inside panel it sends my backup correctly to another server.
Now, I did a schedule backup to do at 3AM mornigs and I'm getting this message per email:
Hello hostmaster!
Your backup process was canceled, because of an error!
Server: my.vmserver.net
Backup type: Server backup
Error message: Remote server error: Unable to connect - incorrect host/port
The weird thing is that the manual remote backup works, but the scheduled one gives error of incorrect details. :shock:
Re: Remote backup problems
Please share the relevant log files of your remote server at the time of the backup, to check if there was a login attempt by the backup system.
Amadex
Re: Remote backup problems  [SOLVED]
Post by Amadex »
The problem resolved itself.
The next day, the scheduled backup did itself at 3AM, and it was working. :oops:
