Email-Warteschlange: Connection refused
yodabosten
Post by yodabosten »
Hallo, ich habe seit einiger Zeit das Problem, dass ich keine Emails mehr empfangen / senden kann.
Alle Emails landen in der Warteschlange mit dem Fehler "connect to 127.0.0.1[127.0.0.1]:10024: Connection refused".
mail.log
Apr  1 11:14:54 vps1 postfix/submission/smtpd[4859]: connect from localhost[127.0.0.1]
Apr  1 11:14:54 vps1 postfix/submission/smtpd[4859]: EB09ABE1D9: client=localhost[127.0.0.1], sasl_method=LOGIN, sasl_username=testing@meinedomain.me
Apr  1 11:14:55 vps1 postfix/cleanup[4862]: EB09ABE1D9: message-id=<69ee75088f2cbe6fc4dca8873ebc36c6@meinedomain.me>
Apr  1 11:14:55 vps1 postfix/qmgr[3285]: EB09ABE1D9: from=<testing@meinedomain.me>, size=2094, nrcpt=1 (queue active)
Apr  1 11:14:55 vps1 postfix/submission/smtpd[4859]: disconnect from localhost[127.0.0.1] ehlo=2 starttls=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=8
Apr  1 11:14:55 vps1 postfix/smtp[4864]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Apr  1 11:14:55 vps1 postfix/smtp[4864]: EB09ABE1D9: to=<empfänger@yahoo.com>, relay=none, delay=0.12, delays=0.11/0.01/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Apr  1 11:14:55 vps1 dovecot: imap-login: Login: user=<testing@meinedomain.me>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4867, TLS, session=<z9AnquW+9oN/AAAB>
Apr  1 11:14:55 vps1 dovecot: imap(testing@meinedomain.me)<4867><z9AnquW+9oN/AAAB>: Logged out in=1954 out=691
Apr  1 11:14:55 vps1 dovecot: imap-login: Login: user=<testing@meinedomain.me>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4869, TLS, session=<abMyquW++oN/AAAB>
Apr  1 11:14:55 vps1 dovecot: imap(testing@meinedomain.me)<4869><abMyquW++oN/AAAB>: Logged out in=70 out=756
Apr  1 11:14:56 vps1 dovecot: imap-login: Login: user=<testing@meinedomain.me>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4873, TLS, session=<gmw/quW+/IN/AAAB>
Apr  1 11:14:56 vps1 dovecot: imap-login: Login: user=<testing@meinedomain.me>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4874, TLS, session=<a3c/quW+/oN/AAAB>
Apr  1 11:14:56 vps1 dovecot: imap(testing@meinedomain.me)<4873><gmw/quW+/IN/AAAB>: Logged out in=76 out=669
Apr  1 11:14:56 vps1 dovecot: imap(testing@meinedomain.me)<4874><a3c/quW+/oN/AAAB>: Logged out in=120 out=801
Apr  1 11:15:01 vps1 dovecot: imap-login: Login: user=<testing@meinedomain.me>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=4937, TLS, session=<KASQquW+AoR/AAAB>
Apr  1 11:15:01 vps1 dovecot: imap(testing@meinedomain.me)<4937><KASQquW+AoR/AAAB>: Logged out in=366 out=2641
Apr  1 11:15:06 vps1 postfix/submission/smtpd[4859]: connect from localhost[127.0.0.1]
Apr  1 11:15:06 vps1 postfix/submission/smtpd[4859]: lost connection after CONNECT from localhost[127.0.0.1]
Apr  1 11:15:06 vps1 postfix/submission/smtpd[4859]: disconnect from localhost[127.0.0.1] commands=0/0
Apr  1 11:15:06 vps1 dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, TLS handshaking: Connection closed, session=<RnbbquW+wo5/AAAB>
Apr  1 11:15:06 vps1 dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=127.0.0.1, lip=127.0.0.1, TLS handshaking: Connection closed, session=<p4DbquW+wLt/AAAB>
Ich denke mal, es hängt mit amavis zusammen.
Wenn ich service amavis status eingebe kommt folgender Fehler:
Can't connect to UNIX socket at file /var/lib/amavis/amavisd.sock [Permission denied]\n  at line 66 in file /usr/share/perl5/Net/Server/Proto/UNIX.pm
service amavis debug output:
root@vps1:/var/log# service amavis debug
Trying to run amavisd-new in debug mode...
Apr  1 11:27:18.010 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: logging initialized, log level 0, syslog: amavis.mail
Apr  1 11:27:18.010 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: sd_notify (no socket): STATUS=Config files have been read, modules loaded.
Apr  1 11:27:18.010 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: starting. /usr/sbin/amavisd-new at vps1.meinserver.me amavisd-new-2.11.0 (20160426), Unicode aware, LANG="en_US.UTF-8"
Apr  1 11:27:18.010 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: perl=5.030000, user=, EUID: 124 (124);  group=, EGID: 131 131 (131 131)
Apr  1 11:27:18.045 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: INFO: no optional modules: unicore::lib::Nt::De.pl Unix::Getrusage
Apr  1 11:27:18.046 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: SpamControl: attempting to load scanner SpamAssassin, module Amavis::SpamControl::SpamAssassin
Apr  1 11:27:18.047 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: SpamControl: scanner SpamAssassin, module Amavis::SpamControl::SpamAssassin
Apr  1 11:27:18.191 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: INFO: SA version: 3.4.4, 3.004004, no optional modules: Encode::Detect Image::Info Image::Info::GIF Image::Info::JPEG Image::Info::PNG Image::Info::BMP Image::Info::TIFF
Apr  1 11:27:18.191 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: SpamControl: init_pre_chroot on SpamAssassin done
Apr  1 11:27:18.191 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: socket module IO::Socket::IP, protocol families available: INET, INET6
Apr  1 11:27:18.191 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: will bind to /var/lib/amavis/amavisd.sock|unix, 127.0.0.1:10024/tcp, [::1]:10024/tcp
Apr  1 11:27:18.191 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: sd_notify (no socket): STATUS=Transferring control to Net::Server.
Apr  1 11:27:18.192 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: sd_notify (no socket): STATUS=Preparing to bind sockets.
Apr  1 11:27:18.192 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: Net::Server: 2021/04/01-11:27:18 Amavis (type Net::Server::PreForkSimple) starting! pid(6273)
Apr  1 11:27:18.196 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: Net::Server: Binding to UNIX socket file "/var/lib/amavis/amavisd.sock"
Apr  1 11:27:18.197 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: (!)Net::Server: 2021/04/01-11:27:18 Can't connect to UNIX socket at file /var/lib/amavis/amavisd.sock [Permission denied]\n  at line 66 in file /usr/share/perl5/Net/Server/Proto/UNIX.pm
Apr  1 11:27:18.197 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: sd_notify (no socket): STOPPING=1\nSTATUS=Server rundown, notifying child processes.
Apr  1 11:27:18.197 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: Net::Server: 2021/04/01-11:27:18 Server closing!
Apr  1 11:27:18.197 vps1.meinserver.me /usr/sbin/amavisd-new[6273]: sd_notify (no socket): STATUS=Child processes have been stopped.
Was kann ich tun? Habt ihr eine Idee?
Danke.
Re: Email-Warteschlange: Connection refused
den Amavis mal neu starten.
yodabosten
Das Problem besteht leider immer noch.
stimmen die Berechtigungen von /var/lib/amavis
stat /var/lib/amavis/
File: '/var/lib/amavis/'
Size: 4096 Blocks: 8 IO Block: 4096 directory
Access: (0750/drwxr-x---) Uid: ( 115/ amavis) Gid: ( 120/ amavis)
