WordPress Installation failed  [SOLVED]
dokabalint
Post by dokabalint »
I installed the One click application installer in the pro version.
I can't install WordPress.
What could be the problem?
vietnamese accent
Re: WordPress Installation failed
please have a look into this file and see, if you can spot any errors:
/var/log/keyhelp/application/<username>.log
There may are also some logs here:
/home/users/<username>/tmp/auto-install/wordpress-<...>/log_exec_<...>
dokabalint
[ID-1] [29-Apr-2021 12:00:03] INFO --> Start application installation process (ID "1")
[ID-1] [29-Apr-2021 12:00:03] INFO --> Application loaded: WordPress
[ID-1] [29-Apr-2021 12:00:03] INFO --> Version loaded: 5.7
[ID-1] [29-Apr-2021 12:00:03] INFO --> Working directory is: /home/users/dokabalint/tmp/auto-install/wordpress-1/
[ID-1] [29-Apr-2021 12:00:03] INFO --> Download URL: https://repository.keyhelp.de/repositor ... 5.7.tar.gz
[ID-1] [29-Apr-2021 12:00:04] INFO --> Archive location: /home/users/dokabalint/tmp/auto-install/wordpress-1/archive.tar.gz
[ID-1] [29-Apr-2021 12:00:04] INFO --> Extracting archive...
[ID-1] [29-Apr-2021 12:00:04] INFO --> Updating file owner to "dokabalint"...
[ID-1] [29-Apr-2021 12:00:04] INFO --> Running setup...
[ID-1] [29-Apr-2021 12:00:06] DEBUG -->
cd '/home/users/dokabalint/tmp/auto-install/wordpress-1/application' ; export WP_CLI_CACHE_DIR=/dev/null ; export TMPDIR='/home/users/dokabalint/tmp/auto-install/wordpress-1/application' ; php wp-cli.phar core download --locale='hu' --version='5.7'
Exit code: 1
Re: WordPress Installation failed  [SOLVED]
--locale='hu'
You have set your profile to a non-official Hungarian translation. Because this language pack is not (yet?) part of the official translations there may be some cases, where it will result in incompatibilities, like this one.
I have fixed the cause in the WordPress setup routine. Please try it again, it should work fine now.
dokabalint
Thank you very much for your quick help and solution. It works! :)
