Postfix smarthost  [SOLVED]
dokabalint
Postfix smarthost
Post by dokabalint »
Dear Everyone,
There is a way to set up smarthost to postfix with the panel? Or can i set manualy in postfix configurations without the panel overwrite it?
Thanks.
Re: Postfix smarthost  [SOLVED]
you must configure this manually in the main.cf
Keyhelp will not overwrite it.
dokabalint
Florian wrote: Fri 7. May 2021, 12:42 Hallo,
It works. Thanks for answer.
