Installation on Ubuntu 16.04 VServer  [GELÖST]
RonnyG
Post by RonnyG »
GutenTag,
Server: Server4you vServer
Mountpoint habe Ich wie in der Anleitung angepasst.
Ich habe immer wieder folgenden Fehler bei der Installation
Installation wird durchgeführt:
Update sources list ...                     [OKAY]
Installation requirements ...               [OKAY]
Sudo ...                                    [OKAY]
Bind9 ...                                   [OKAY]
SSL/TLS ...                                 [OKAY]
PHP ...                                     [OKAY]
Apache web server ...                       [ERROR]
PHP-FPM ...                                 [ERROR]
MariaDB ...                                 [OKAY]
KeyHelp ...                                 [ERROR]
Firewall ...                                [ERROR]
SSH ...                                     [OKAY]
ProFTPD ...                                 [OKAY]
Postfix ...                                 [OKAY]
Dovecot ...                                 [OKAY]
OpenDKIM ...                                [OKAY]
Email protection ...                        [OKAY]
AWStats ...                                 [OKAY]
Fail2ban ...                                [OKAY]
Logrotate ...                               [OKAY]
PhpMyAdmin 4.9.7 ...                        [OKAY]
Adminer 4.8.0 ...                           [OKAY]
Roundcube 1.4.11 Multilanguage ...          [OKAY]
Rainloop 1.15.0 (Community Edition) ...     [OKAY]
Quota ...                                   [ERROR]
Apparmor ...                                [OKAY]
7-zip ...                                   [OKAY]
Update message of the day ...               [OKAY]
Nano ...                                    [OKAY]
Cron daemon ...                             [OKAY]
Warning: MySQL - Connection Error: 1045 (Access denied for user 'keyhelp'@'localhost' (using password: YES)) in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 253
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 53
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 54
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 55
Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 78
Warning: DBConnection::query(): Couldn't fetch mysqli in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 79
Fatal error: Uncaught Error: Call to a member function fetch_assoc() on null in /home/keyhelp/www/keyhelp/core/Settings/Settings.php:251
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/Settings/Settings.php(50): Settings->loadSettings()
#1 /home/keyhelp/www/keyhelp/install/install.php(841): Settings->__construct(Object(DBConnection))
#2 {main}
  thrown in /home/keyhelp/www/keyhelp/core/Settings/Settings.php on line 251
Denn Server habe Ich jetzt auch schon mehrmals neu aufgesetz aber immer der selbe Fehler.
Re: Installation on Ubuntu 16.04 VServer
Die Gründe der Fehler sollten in /var/log/keyhelp/install.log zu finden sein, hier nach "Error detected" suchen.
Aber mal was anderes, warum versuchst du Ubuntu 16 zu installieren? Das OS hat seinen End-Of-Life Status erreicht und erhält keine weiteren Updates.
RonnyG
Re: Installation on Ubuntu 16.04 VServer  [GELÖST]
Post by RonnyG »
Vielen Dank für den Hinweis.
Der Fehler kommt vom Apache, der nicht Installiert wird.
Das ist leider die höchste version die Server4You anbietet :?
Fehler:
E: Package 'libapache2-mod-fastcgi' has no installation candidate
gelöst mit
wget https://mirrors.edge.kernel.org/ubuntu/pool/multiverse/liba/libapache-mod-fastcgi/libapache2-mod-fastcgi_2.4.7~0910052141-1.2_amd64.deb
sudo dpkg -i libapache2-mod-fastcgi_2.4.7~0910052141-1.2_amd64.deb
RonnyG wrote: Tue 25. May 2021, 12:48 Vielen Dank für den Hinweis.
Fehler:
gelöst mit
Weil S4U der unfähigste Verein aurf dem Markt ist.
Blackmoon
Post by Blackmoon »
RonnyG wrote: Tue 25. May 2021, 12:48 Das ist leider die höchste version die Server4You anbietet :?
Für das von dir gemiete Produkt. Neuere Versionen von Ubuntu werden in einem anderen Tarif (https://www.server4you.de/virtual-dedicated-server) problemlos angeboten.
