vServer 1blu - Virtuzzo - Ubuntu 18.04 Minimal
Hochhrhein-RK
Post by Hochhrhein-RK »
Hallo, leider habe ich schon einiges durch probiert was ich an event. Lösungen hier im Forum finden konnte.
Allerdings komme ich auf im Betreff genannter Konfiguration / Installation nicht weiter mit dem Quota. Hoffe es gibt dafür eine Lösung.
Ein neuer Server ist keine Option zur Zeit.
Fehler LOG der Key Help Installation:
Quota
exec | apt-get install -y quota quotatool
Reading package lists...
Building dependency tree...
Reading state information...
quota is already the newest version (4.04-2ubuntu0.1).
The following NEW packages will be installed:
quotatool
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 15.7 kB of archives.
After this operation, 48.1 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/universe amd64 quotatool amd64 1:1.4.12-2build1 [15.7 kB]
Fetched 15.7 kB in 0s (356 kB/s)
Selecting previously unselected package quotatool.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 37263 files and directories currently installed.)
Preparing to unpack .../quotatool_1%3a1.4.12-2build1_amd64.deb ...
Unpacking quotatool (1:1.4.12-2build1) ...
Setting up quotatool (1:1.4.12-2build1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
exec | service quota stop
exec | cp /etc/fstab /etc/fstab-backup
exec | echo "/dev/simfs / simfs rw,relatime,usrquota,grpquota 0 1
proc /proc proc defaults 0 0
none /dev/pts devpts rw,gid=5,mode=620 0 0
none /run/shm tmpfs defaults 0 0" > "/etc/fstab"
exec | mount -o remount /
mount: /: permission denied.
[SKIPPED DUE PREVIOUS ERRORS] exec | quotacheck -avmug
[SKIPPED DUE PREVIOUS ERRORS] exec | service quota start
Ich hoffe es gibt dafür einen Ansatz.
Re: vServer 1blu - Virtuzzo - Ubuntu 18.04 Minimal
Einmal das Folgende, ab dem verlinkten Beitrag beginnend, lesen (bis zum letzten Beitrag von technotravel):
viewtopic.php?p=26309#p26309
Hochhrhein-RK
Danke für den Hinweis. D.h. ich muss den Support von 1blu anschreiben und ihn danach fragen?
Sorry, aber damit hab ich bisher so noch nie zu tun gehabt.
