Remote Backup FTP old files not deleted
Drewpy
Post by Drewpy »
The old backups are not deleted on the ftp, however I have set maximum number of files in remote repository to 7
The ftp account used has the rights to delete files
From "Stored backups" -> "Remote", I can delete old files
Keyhelp version: 21.0 (Build 2195)
Operating system: Debian 10.9 (64-bit)
Keyhelp backup logs :
[05-Jun-2021 02:00:01] INFO  --> start backup process, task ID: "36"
[05-Jun-2021 02:00:01] INFO  --> prepare processing dir
[05-Jun-2021 02:00:01] INFO  --> deleteDirectory(): the directory "/backup/processing/task-36/" does not exists
[05-Jun-2021 02:00:01] INFO  --> write pid file
[05-Jun-2021 02:00:01] INFO  --> check remote connection
[05-Jun-2021 02:00:02] INFO  --> estimate disk space needed for this job
[05-Jun-2021 02:00:02] INFO  --> write "allocated" file
[05-Jun-2021 02:00:02] INFO  --> free: 91,021.54 MiB
[05-Jun-2021 02:00:02] INFO  --> reserve: 4,988.62 MiB (5%)
[05-Jun-2021 02:00:02] INFO  --> this backup task: 569.22 MiB
[05-Jun-2021 02:00:02] INFO  --> all running backup tasks: 569.22 MiB
[05-Jun-2021 02:00:02] INFO  --> generate archive directories
[05-Jun-2021 02:00:02] INFO  --> backup type is "server"
[05-Jun-2021 02:00:02] INFO  --> backup config
[05-Jun-2021 02:00:03] INFO  --> backup user databases
[05-Jun-2021 02:00:03] INFO  --> backup non-user databases
[05-Jun-2021 02:00:04] INFO  --> backup home directories
[05-Jun-2021 02:00:04] INFO  --> backup mail directories
[05-Jun-2021 02:00:04] INFO  --> create one backup file
[05-Jun-2021 02:00:04] INFO  --> file name is /backup/processing/task-36/server-servername-20210605020004.7z
[05-Jun-2021 02:00:04] INFO  --> compressing file
[05-Jun-2021 02:00:04] INFO  --> ... with compressing level set to: "fast"
[05-Jun-2021 02:00:10] INFO  --> compressing done
[05-Jun-2021 02:00:10] INFO  --> sha1 checksum: ba749e2fe35649618f61ed6dc49d34ffe635c8a3
[05-Jun-2021 02:00:10] INFO  --> remove archive directory
[05-Jun-2021 02:00:10] INFO  --> deleteDirectory(): perform rm -rf /backup/processing/task-36/archive/
[05-Jun-2021 02:00:10] INFO  --> move file to remote repository
[05-Jun-2021 02:00:10] INFO  --> apply rotation  - keep max. 7 file(s) in repository
[05-Jun-2021 02:00:11] INFO  --> no files on remote server found
[05-Jun-2021 02:00:13] INFO  --> cleanup
[05-Jun-2021 02:00:13] INFO  --> deleteDirectory(): perform rm -rf /backup/processing/task-36/
[05-Jun-2021 02:00:13] INFO  --> backup finished
[06-Jun-2021 02:00:02] INFO  --> start backup process, task ID: "37"
[06-Jun-2021 02:00:02] INFO  --> prepare processing dir
[06-Jun-2021 02:00:02] INFO  --> deleteDirectory(): the directory "/backup/processing/task-37/" does not exists
[06-Jun-2021 02:00:02] INFO  --> write pid file
[06-Jun-2021 02:00:02] INFO  --> check remote connection
[06-Jun-2021 02:00:02] INFO  --> estimate disk space needed for this job
[06-Jun-2021 02:00:03] INFO  --> write "allocated" file
[06-Jun-2021 02:00:03] INFO  --> free: 91,032.87 MiB
[06-Jun-2021 02:00:03] INFO  --> reserve: 4,988.62 MiB (5%)
[06-Jun-2021 02:00:03] INFO  --> this backup task: 569.22 MiB
[06-Jun-2021 02:00:03] INFO  --> all running backup tasks: 569.22 MiB
[06-Jun-2021 02:00:03] INFO  --> generate archive directories
[06-Jun-2021 02:00:03] INFO  --> backup type is "server"
[06-Jun-2021 02:00:03] INFO  --> backup config
[06-Jun-2021 02:00:03] INFO  --> backup user databases
[06-Jun-2021 02:00:03] INFO  --> backup non-user databases
[06-Jun-2021 02:00:04] INFO  --> backup home directories
[06-Jun-2021 02:00:05] INFO  --> backup mail directories
[06-Jun-2021 02:00:05] INFO  --> create one backup file
[06-Jun-2021 02:00:05] INFO  --> file name is /backup/processing/task-37/server-servername-20210606020005.7z
[06-Jun-2021 02:00:05] INFO  --> compressing file
[06-Jun-2021 02:00:05] INFO  --> ... with compressing level set to: "fast"
[06-Jun-2021 02:00:11] INFO  --> compressing done
[06-Jun-2021 02:00:11] INFO  --> sha1 checksum: 0ad92c068ed536726634a4f7e2adb78acfff8fb3
[06-Jun-2021 02:00:11] INFO  --> remove archive directory
[06-Jun-2021 02:00:11] INFO  --> deleteDirectory(): perform rm -rf /backup/processing/task-37/archive/
[06-Jun-2021 02:00:11] INFO  --> move file to remote repository
[06-Jun-2021 02:00:12] INFO  --> apply rotation  - keep max. 7 file(s) in repository
[06-Jun-2021 02:00:12] INFO  --> no files on remote server found
[06-Jun-2021 02:00:14] INFO  --> cleanup
[06-Jun-2021 02:00:14] INFO  --> deleteDirectory(): perform rm -rf /backup/processing/task-37/
[06-Jun-2021 02:00:14] INFO  --> backup finished
Remote FTP server log
Jun  6 02:00:02 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] New connection from KEYHelp-Server
Jun  6 02:00:02 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES128-GCM-SHA256, 128 secret bits cipher
Jun  6 02:00:02 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] ftp-user is now logged in
Jun  6 02:00:02 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES128-GCM-SHA256, 128 secret bits cipher
Jun  6 02:00:02 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [NOTICE] /home/backup//server-name/keyhelp-remote-test.dat uploaded  (21 bytes, 0.40KB/sec)
Jun  6 02:00:02 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [NOTICE] Deleted /home/backup//server-name/keyhelp-remote-test.dat
Jun  6 02:00:02 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [INFO] Logout.
Jun  6 02:00:11 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] New connection from KEYHelp-Server
Jun  6 02:00:11 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES128-GCM-SHA256, 128 secret bits cipher
Jun  6 02:00:12 my-ftp pure-ftpd: (?@KEYHelp-Server) [INFO] ftp-user is now logged in
Jun  6 02:00:12 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [INFO] TLS: Enabled TLSv1/SSLv3 with ECDHE-RSA-AES128-GCM-SHA256, 128 secret bits cipher
Jun  6 02:00:14 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [NOTICE] /home/backup//server-name/server-server-name-20210606020005.7z uploaded  (61661490 bytes, 25824.61KB/sec)
Jun  6 02:00:14 my-ftp pure-ftpd: (ftp-user@KEYHelp-Server) [INFO] Logout
Best regards
Re: Remote Backup FTP old files not deleted
Maybe there is an issue with your pure-ftp configuration, as it works fine with other FTP servers.
You probably also want to try to switch to SFTP.
Anyway the old Backup system will not receive any bigger updates anymore, in favor of a new Backup system.
Drewpy
Post by Drewpy »
Until the new backup system, I will delete the old files by hand
