Dropbox Add repository Error  [SOLVED]
gustavohellwig
Post by gustavohellwig »
When you try to add a Dropbox Backup Repository, appears this error:
Error connecting app:
This app has reached its user limit. Contact the app developer and ask them to use the Dropbox API App Console to increase their app's user limit.
What should I do to fix that?
Re: Dropbox Add repository Error  [SOLVED]
There is nothing you can do about this for now.
I am in contact with the Dropbox support, to get the reason, why this message is shown - the KeyHelp Dropbox app is nowhere near its app's user limit...
After the investigation has finished (depends on how fast the Dropbox team will respond) i will give an update here.
=> EDIT: The issue is now fixed. You can link Dropbox accounts again.
gustavohellwig
OK, well done, it's ok again.
You D man !!!!
