Easy to Install PHP extensions  [SOLVED]
martins
Post by martins »
It would be nice to add the option to install all the available PHP extensions through the panel itself via Multi-PHP selection option. So far we can do it manually via terminal but takes more time to get the operation done.
Sorry for my English
DracoBlue
Re: Easy to Install PHP extensions
Post by DracoBlue »
Good idea
space2place
Post by space2place »
martins wrote: Mon 2. Aug 2021, 04:24 It would be nice to add the option to install all the available PHP extensions through the panel itself via Multi-PHP selection option. So far we can do it manually via terminal but takes more time to get the operation done.
This is a work you have to do on console. Just my 2 cent.
boka003
Post by boka003 »
I was taking a look at all future requests (english and german) and this one looks most important to me.
Right now, if the user wants to enable some php extension (or disable) or increase value, it need to contact admin?
raselmx
Post by raselmx »
I can do it from the SSH terminal but it would be very much helpful if it can be done directly from the keyhelp admin panel.
Re: Easy to Install PHP extensions  [SOLVED]
currently there are no plans to include this in the user interface. I don't see why this is necessary. Normally this would be a one time operation anyway.
"My client needs php-intl, okay, I open the CLI and type 'apt install php-intl' -> Done".
However, if you come across extensions that you need to install regularly, I have no problem adding them to the default PHP extensions that KeyHelp installs during installation.
