Outbound Port 25 for Postfix only in Firewall
latifolia
Post by latifolia »
We have plan to reduce possible spam initated from our server to outside world by limiting access to outbound port 25 only for Postfix with this kind of code in firewall :
iptables -I OUTPUT -m owner ! --uid-owner postfix -m tcp -p tcp --dport 25 -j REJECT --reject-with icmp-admin-prohibited
Is that okay or will that be problems with KeyHelp configuration?
We plan to add it manually via custom script since we can not add it through KeyHelp Firewall GUI (or do u know how to do it there?).
Need your opinion
Re: Outbound Port 25 for Postfix only in Firewall
Spam initiated by your server?
Either you have an open relay or one of your users is responsible for the spam.
IMHO blocking port 25 will not solve the issue.
latifolia
Post by latifolia »
There are no spams .. yet. It is planned as anticipation so there we need opinion whether the plan is feasible or not.
Most spam which is originated using scripts going through Postfix can be handled accordingly, the problem lies on accessing outbond port 25 by unknown scripts bypassing Postfix as MTA.
Thus, we try to limit access to outbound port 25 only for Postfix to limit the possible spams initiated.
Also it would be fantastic to have Firewall GUI which can have matches in rules, like code above.
latifolia wrote: Wed 18. Aug 2021, 09:15 Is that okay or will that be problems with KeyHelp configuration?
If you would like to use rules, which cannot be build via the KeyHelp UI, I would advise, to turn off the KeyHelp firewall and manage the rules completely on your own.
This way, your custom rules cannot be accidentally overwritten when you use the KeyHelp firewall UI. Also, the custom rules will not survive a server reboot if KeyHelp Firewall is still active.
