Why domain will auto add default domain?
akong77
Post by akong77 »
My default domain is aspa.idv.tw
So every domain dns will auto add default domain.
I use nslookup to test it.
> www.mouse-team.com.tw
Server: dns.google
Address: 8.8.8.8
未經授權的回答:
Address: 139.99.19.248
What is this problem and how to fix it?
Re: Why domain will auto add default domain?
You must end the domain in the DNS with a dot (for example mouse-team.com.tw.), otherwise the default domain will be appended to the actual domain. This is the normal holding in bind (the name server)
akong77
Post by akong77 »
I use keyhelp dns server.Could it's not end the domain in the DNS with a dot?
For the entries that Keyhelp sets the dot is set automatically, for entries that you add manually it is not set
