http 1.1 or 2.0?  [SOLVED]
info@eurhosting.net
Post by info@eurhosting.net »
Hello
Does keyhelp use http 2.0 or still 1.1? In case of 1.1 is it possible to upgrade to 2.0?
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
Re: http 1.1 or 2.0?
HTTP/2 if you use https and the client supports it.
HTTP/2 is used on all currently supported operating systems.
So if you are running something >= Debian 9 or >= Ubuntu 18.04, HTTP/2 is always enabled.
