Roundcube Bug
Roundcube Bug
There is currently a bug in the Roundcube.
Problem
If you experience the phenomenon that no mails can be sent anymore and it shows a loading animation for a very long time, then you are probably affected.
Affected are:
Affected should only be mailboxes that have "Spellcheck options" enabled in the Roundcube settings -> "Composing Messages".
Cause
The Roundcube developers got a server shut down that they were using for spellchecking.
Info of the Roundcube team: https://roundcube.net/news/2021/09/14/s ... rvice-down
Solution
A small change in the Roundcube config can help.
1) Open both files:
/home/keyhelp/www/keyhelp/install/templates/roundcube/config.inc.php
and
/home/keyhelp/www/roundcube/config/config.inc.php
2) At the end of the file, paste the following and save.
$config['enable_spellcheck'] = false;
The Problem has been solved: https://roundcube.net/news/2021/09/28/s ... ack-online
