How to change panel url with ssl name?  [SOLVED]
akong77
Post by akong77 »
My keyhelp orig panel name is panel.aspa.idv.tw.But I want change to panel.8898go.com.I change hostname and set letsencrypt to panel.8898go.com this hostname.But when I open keyhelp panel with https://panel.8898go.com.It's will show 404 not found.I make sure DNS is normal running.How to do fix?
Re: How to change panel url with ssl name?  [SOLVED]
I have checked your domain and it seams to work fine now.
Changes to DNS may need 24 hours to be applied everywhere, depending on the TTL value of the DNS records.
