DNS Editor: CNAME  [SOLVED]
kivamp
DNS Editor: CNAME
Post by kivamp »
Hi!
DNS Editor:
Can't create CNAME with special names, wich begining with underscore.
Such as: _domainkey, _sip, etc...
Eoler
Re: DNS Editor: CNAME
Post by Eoler »
kivamp wrote: Mon 25. Oct 2021, 19:04 DNS Editor:
Those are TXT/SRV records, CNAME never starts with underscore...
kivamp
Post by kivamp »
_dmarc CNAME _dmarc.other.domain.
this is a valid entry !
Re: DNS Editor: CNAME  [SOLVED]
The cname validation, implemented with KeyHelp 21.2 was a bit off. I already fixed it for 21.3 multiple days ago, so it should work like expected with the next KeyHelp update.
Meanwhile you can modify the bind config file directly: /etc/bind/keyhelp_domains/<DOMAIN-NAME>
