IMAP & POP3
latifolia
IMAP & POP3
Post by latifolia »
Hi there,
I need to permanently keep IMAP and disable POP3 so everyone should only use IMAP.
How to do that?
Re: IMAP & POP3
e.g. you can block the ports 110 and 995 via firewall
AstroLulu
Re: IMAP & POP3
Post by AstroLulu »
In addition to that: Does IMAP need DNS Records in order to work properly? All the ports are free, but I cannot connect to the Email in another program for example in Outlook. Not with POP3 neither with IMAP.
Re: IMAP & POP3
that depends on teh settings you made in your mail client.
The hostnames you use for the SMTP- and POP3/IMAP server should point to the server and shoudl be secured by a certificate.
Of course you can also use the IPs of your server, but then you will face certificate warnings.
