subdomain root directory
dioporken
Post by dioporken »
when an user creates a subdomain the root directory defaults to the domain www/ directory, and it is not possible to create anytyng before that www/ ... In every other administration panel the norm is different: when an user creates a subdomain in is automatically created a subdomain.domain.xxx directory in the root, which than has its own www/
if my subdomain must use a subdirectory of the main domain what's the point of having a subdomain? is is a security issue too :?
MLan
Re: subdomain root directory
Post by MLan »
just create a new user for the subdomain
Don‘t start with your first domain in the „www“ directory.
Just put the domains in the following scheme:
/www/domain1.tld/
/www/domain2.tld/
/www/and_so_on/
christian.john
Post by christian.john »
You could use /www/tld.xxx/ for you tld domain and /www/sub.tld.xx/ for you sublevel domain
moved to „usage & configuration.
This is obviously not a bug.
Please stick to this topic and don‘t start another thread about this question.
