KeyHelp Main Website Down  [SOLVED]
Tony20
Post by Tony20 »
Hello, the main website www.keyhelp.de is not accessible.
Re: KeyHelp Main Website Down
Hello!
Thank you for the information.
After checking: From our side, all systems are running at nominal.
pleese send a tracroute to www.keyhelp.de and also send the source IP.
Tony20
Post by Tony20 »
I get a blank page on the https://www.keyhelp.de/en/ website, I try it with different web browsers, same result.
There is a post on LowEndTalk reporting this problem on the Keyhelp main website.
what happend to keyhelp panel?
https://www.lowendtalk.com/discussion/comment/3301783
Ahhh, thank you, seams that only the English part of our website has some kind of an error. I start to investigate.
Tony20
Post by Tony20 »
Alexander wrote: Wed 17. Nov 2021, 14:48 Ahhh, thank you, seams that only the English part of our website has some kind of an error. I start to investigate.
All good now, thanks!
Strange things happen. Surfing to www.keyhelp.de with newest Firefox browser from my Windows 10 PC, the page loads for a looooong time. Then the URL changes to https:/www.keyhelp.de/en/ showing a white page with a HTML source of
<!DOCTYPE html>
<html lang="en-US">
<head>
	<meta charset="UTF-8" />
<meta http-equiv="X-UA-Compatible" content="IE=edge">
	<link rel="pingback" href="https://www.keyhelp.de/xmlrpc.php" />
	<script type="text/javascript">
		document.documentElement.className = 'js';
	</script>
	<script>var et_site_url='https://www.keyhelp.de';var et_post_id='4612';function et_core_page_resource_fallback(a,b){"undefined"===typeof b&&(b=a.sheet.cssRules&&0===a.sheet.cssRules.length);b&&(a.onerror=null,a.onload=null,a.href?a.href=et_site_url+"/?et_core_page_resource="+a.id+et_post_id:a.src&&(a.src=et_site_url+"/?et_core_page_resource="+a.id+et_post_id))}
</script><!DOCTYPE html>
<html lang="en-US">
<head>
	<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
	<meta name="viewport" content="width=device-width">
OTOH, the server seems to be up and running, traceroute works using IPv4 and v6.
Edit: Website seems to be working again.
Edit: Just tried again and it seems to be up and running again
Re: KeyHelp Main Website Down  [SOLVED]
I "played" around with the settings the last couple of minutes. So there may be times, where it worked and times where it did not.
From now on, all should be fine again. Thank you very much for reporting!
