Backups using WebDAV  [SOLVED]
gusarg81
Post by gusarg81 »
I am trying to setup a Backup repository using WebDav (in this case, with installed Nextcloud in remote server), but gives me this error:
Failed to connect to repository storage.
ERROR : Attempt 1/1 failed with 1 errors and: Update mkParentDir failed: Mkcol "https://home.ddns.gdnet.ar/nextcloud/re ... t_Backups/": x509: certificate signed by unknown authority
Failed to touch: Update mkParentDir failed: Mkcol "https://home.ddns.gdnet.ar/nextcloud/re ... t_Backups/": x509: certificate signed by unknown authority
Just in case, that domain uses LetsEncrypt cert.
Any ideas? Thanks.
Re: Backups using WebDAV  [SOLVED]
your server probably not have the latest version of CA certificates installed.
You may want to try to update your local CA certificates with the following command.
update-ca-certificates
Furthermore, your certificate chain on your server seems to be incomplete:
https://www.ssllabs.com/ssltest/analyze ... Results=on
gusarg81
Post by gusarg81 »
Hi!
Thanks for the tip. For future references, I've fixed this by adding this line to the apache virtualhost corresponding to home.ddns.gdnet.ar:
SSLCertificateChainFile /etc/letsencrypt/live/home.ddns.gdnet.ar/chain.pem
So, full SSL line I've used now is:
SSLEngine On
SSLCertificateFile /etc/letsencrypt/live/home.ddns.gdnet.ar/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/home.ddns.gdnet.ar/privkey.pem
Now adding WebDAV backup repository works.
Thanks again!
