Php issue for any version. (Arm AARCH64)  [SOLVED]
Alaura
Post by Alaura »
I don't know if the panel supports ARM, but i'm getting a issue on the php side of things, for example
Php: sh: 1: /opt/keyhelp/php/8.1/bin/php: Exec format error
Breaks php meaning i can't use it at all.
Re: Php issue for any version. (Arm AARCH64)  [SOLVED]
ARM is supported by KeyHelp but the additional PHP interpreter are currently not compiled for ARM systems (and therefor will not work).
This may change if more people use ARM systems.
