API PUT /dns/{id} resets DNS zone  [SOLVED]
superrandom
Post by superrandom »
(Problems not related to KeyHelp belong in the Offtopic forum)
Debian 10.11
22.0 - build 2393
When issuing a POST request to /dns/{id} the response seems to match your documentation's success confirmation, returning the same {id} back. However, when I check that the update was made to the dns zone, I find the domain reverts back to defaults, including TTL value.
Expected result
Only the passed record should be updated, and no other changes should be made to the dns zone.
Actual result
DNS zone seems to be reset to defaults, affecting everything about the whole domain, removing records not available by default.
Steps to reproduce
1. Add a record to a dns zone.
2. make a PUT request to /dns/{id} and pass a payload that should update an existing custom (not what keyhelp usually starts with when adding a domain) record.
3. Refresh the admin page for the DNS zone, and observe all custom records are now gone, reverting to a standard domain dns zone, including TTL entries.
Additional information
I cannot find logs about API requests. No php errors noted.
Payload passed:
	"is_dns_disabled": false,
    "records": {
        "other": [
                "host": "office",
                "ttl": 300,
                "type": "A",
                "value": "2.2.2.2"
                "host": "text",
                "ttl": 300,
                "type": "A",
                "value": "1.1.1.1"
Re: API PUT /dns/{id} resets DNS zone  [SOLVED]
superrandom wrote: Sun 27. Mar 2022, 04:30 DNS zone seems to be reset to defaults, affecting everything about the whole domain, removing records not available by default.
You have to put the whole zone.
„Attention, when inserting custom DNS records, you have to specify all records not just the one you want to update.“
