ClamAv High memory consuption, OOm killer in action
TLoF
Post by TLoF »
Debian 11.3 64bit
Proxmox
KeyHelp 22.0 (Build 2393)
When the clamav update, the server run out of memory, and the OOm killer randomly kill something. If it is an fpm process it is not a problem, if it is a mysqld process it is a problem.
Expected result
Everything working normal
Actual result
Mysqld Killed by OOm killer
Steps to reproduce
4 GB ram, no swap, random event.
Additional information
Debian 11.3, fresh install, two sites, both run php7.3.
There is a new switch to ClamAV called ConcurrentDatabaseReload If it sets to no, it reduce the memory consuption on new updates. I suggest it will be a default, or a configurable item.
https://blog.clamav.net/2020/09/clamav- ... eased.html
Re: ClamAv High memory consuption, OOm killer in action
If you have no option to increase RAM, use a swap partition or file of at least 8 GB.
this is not an issue of KeyHelp.
By the way, you can turn ClamAV email checks off, which should save you lots of RAM.
Go to KeyHelp Admin Area -> "Configuration" -> "Email Server" -> Uncheck the "Email virus checks" checkbox
BasHeijermans
Post by BasHeijermans »
You can always remove the oom-killer, then the problem is gone.
apt remove oomd
And remove some databases from the database-list or disable Anti-Virus.
Then your 4GB will be more then enough.
Greetings Bas.
