Default chown  [SOLVED]
Re: Default chown  [SOLVED]
Sorry to say, but you are really f*cked up.
The net is full of the same problem, no, there is no reasonable way to repair that.
Take a backup, and make a fresh install. Then restore, KH will take care of the rest.
