amavis Fehler beim Startup  [GELÖST]
Henning
Post by Henning »
Vermutlich
Debian 11.3
22.0 2393
ay 4 11:54:11 zeus amavis[627]: starting. /usr/sbin/amavisd-new at zeus.nieland.io amavisd-new-2.11.1 (20181009), Unicode aware, LANG="de_DE.UTF-8"
May 4 11:54:11 zeus amavis[627]: perl=5.032001, user=116, EUID: 116 (116); group=, EGID: 122 121 122 (122 121 122)
May 4 11:54:12 zeus amavis[627]: Net::Server: Group Not Defined. Defaulting to EGID '122 121 122'
May 4 11:54:12 zeus amavis[627]: Net::Server: User Not Defined. Defaulting to EUID '116'
May 4 11:54:12 zeus amavis[627]: No ext program for .lrz, tried: lrzip -q -k -d -o -, lrzcat -q -k
May 4 11:54:12 zeus amavis[627]: No ext program for .lzo, tried: lzop -d
May 4 11:54:12 zeus amavis[627]: No ext program for .lz4, tried: lz4c -d
May 4 11:54:12 zeus amavis[627]: No ext program for .rpm, tried: rpm2cpio.pl, rpm2cpio
May 4 11:54:12 zeus amavis[627]: No ext program for .rar, tried: unrar-free
May 4 11:54:12 zeus amavis[627]: No ext program for .arj, tried: arj, unarj
May 4 11:54:12 zeus amavis[627]: No ext program for .arc, tried: nomarch, arc
May 4 11:54:12 zeus amavis[627]: No ext program for .zoo, tried: zoo
May 4 11:54:12 zeus amavis[627]: No ext program for .doc, tried: ripole
May 4 11:54:12 zeus amavis[627]: No ext program for .cab, tried: cabextract
May 4 11:54:12 zeus amavis[627]: No ext program for .exe, tried: unrar-free; arj, unarj
May 4 11:54:12 zeus amavis[627]: No decoder for .F
May 4 11:54:12 zeus amavis[627]: No decoder for .arc
May 4 11:54:12 zeus amavis[627]: No decoder for .doc
May 4 11:54:12 zeus amavis[627]: No decoder for .exe
May 4 11:54:12 zeus amavis[627]: No decoder for .lrz
May 4 11:54:12 zeus amavis[627]: No decoder for .lz4
May 4 11:54:12 zeus amavis[627]: No decoder for .lzo
May 4 11:54:12 zeus amavis[627]: No decoder for .zoo
May 4 11:54:12 zeus amavis[627]: Using primary internal av scanner code for ClamAV-clamd
May 4 11:54:12 zeus amavis[627]: Found secondary av scanner ClamAV-clamscan at /usr/bin/clamscan
Keine Fehlermeldung
Fehlermeldung
Bei jedem reboot des Servers oder auch restart des Dienstes
Wie relevant sind diese Meldungen?
Freundliche Grüße von Henning
Re: amavis Fehler beim Startup  [GELÖST]
Das ist keine Fehlermeldung sondern eine Infomeldung.
Falls du möchtest, dass deine Clam-Av Instanz auch exotische Dateiendungen scannt musst du dementsprechend die Zusatzprogramme installieren und konfigurieren.
MLan
Post by MLan »
Tobi wrote: Wed 4. May 2022, 13:09 Falls du möchtest, dass deine Clam-Av Instanz auch exotische Dateiendungen scannt musst du dementsprechend die Zusatzprogramme installieren und konfigurieren.
zb
apt install libclamunrar9
Dann werden auch rar files gescannt
Henning
Post by Henning »
Prima, vielen Dank für eure Antworten.
