Crontab for learning Spam seems to be Wrong  [SOLVED]
amarc
Post by amarc »
in /etc/cron.d/keyhelp-sa-learn you have:
30 0 * * * root nice /usr/bin/sa-learn --dbpath /var/spool/spamassassin --spam /var/mail/vhosts/*/*/.Junk > /dev/null
which does nothing as Spam/Junk folder on mailboxes is called
.Junk E-mail
I could not find where do you declare this "special folder" in dovecot so I fixed crontab with
30 0 * * * root nice /usr/bin/sa-learn --dbpath /var/spool/spamassassin --spam /var/mail/vhosts/*/*/.Junk\ E-mail > /dev/null
So IMO, there should either be fix on how is "Junk" folder named or above crontab script should be fixed as per above.
A.
Debian 11
22.0 (Build 2393)
Re: Crontab for learning Spam seems to be Wrong
the default folder is named Junk so the cronjob is correct.
Maybe you have renamed the folder?
which mail client are you using for connecting to your mailbox?
amarc
Post by amarc »
Florian wrote: Fri 13. May 2022, 10:22 Hallo,
No I did not. I tested this by creating brand new account and waiting for it to be created on filesystem. Than simple
ls
on that new account would show
.Junk E-mail
So to answer Alexander too.. I did not even connect to email at all as this was tested and discovered on brand new accounts
Edit: it does seem like folder is not created until first login. So to answer that question. Rainloop via IMAP but outside Keyhelp (on external domain)
amarc
Post by amarc »
Additionally, dovecot/conf.d/15-mailboxes.conf should contain
mailbox Spam {
    special_use = \Junk
    auto = subscribe
under
namespace inbox {
As a lot of mail clients are naming Junk as Spam. I tried to add above in /etc/dovecot/local.conf but nothing really hapens
Re: Crontab for learning Spam seems to be Wrong  [SOLVED]
Yes, unfortunately Rainloop does not stick to the recommended names (by RFC) if they are not supplied.
I've now put the following in /etc/dovecot/conf.keyhelp.d/15-mailboxes.conf
And it worked (when creating a new mail account and log in the first time with Rainloop).
Take it with a grain of salt, is this was just a quick test. I will implement it within the next KeyHelp Update 22.1, but the content of the file below very likely change a bit.
namespace inbox {
  inbox = yes
  # These mailboxes are widely used and could perhaps be created automatically:
  mailbox Drafts {
    auto = subscribe
    special_use = \Drafts
  mailbox Junk {
    auto = subscribe
    special_use = \Junk
  mailbox Trash {
    auto = subscribe
    special_use = \Trash
  # For \Sent mailboxes there are two widely used names. We'll mark both of
  # them as \Sent. User typically deletes one of them if duplicates are created.
  mailbox Sent {
    auto = subscribe
    special_use = \Sent
  mailbox "Sent Messages" {
    auto = subscribe
    special_use = \Sent
amarc
Post by amarc »
Thanks. I will update it manually until 22.1. Basically you added auto = subscribe ?
Files within /etc/dovecot/conf.d are not included, only files in /etc/dovecot/conf.keyhelp.d/ are taken into account.
However, changes in the local.conf should work too. I have not testet it with the local.conf. Instead i put it right into the /etc/dovecot/conf.keyhelp.d/15-mailboxes.conf.
I have start testing with auto = create. But will change it to auto = subscribe with KeyHelp 22.1
amarc
Post by amarc »
But at least on my installation /etc/dovecot/conf.keyhelp.d/ does not contain 15-mailboxes.conf at all . I only have: 10-auth.conf 10-services.conf 10-ssl.conf 20-protocols.conf 90-plugins.conf there.
Yes, this file will part of the upcoming update. Currently it does not exist.
You can already put the file there, it will simply be overwritten with the next update.
amarc
Post by amarc »
Great, thanks 👍
I tested it and can confirm all works as expected.. Only .Junk folder is present
ShortSnow
Post by ShortSnow »
testet the new config file. Ist much better then before. It corrects also "Send" and "Trash". So far I've adjusted it by hand.
A small blemish:
There is now an unused folder: Sent Messages
THX Arne
Thank you for testing ;)
ShortSnow wrote: Fri 13. May 2022, 14:56 There is now an unused folder: Sent Messages
This is because of this part of the above config:
  mailbox Sent {
    auto = subscribe
    special_use = \Sent
    auto = subscribe
    special_use = \Sent
and the reason why I am said, the content of the file may change until release ;).
Currently I am unsure if I should keep the "Sent Messages" folder, or if it is just a relic of the past.
I have a feeling I've encountered Apple Mail utilize this folder - but currently I don't have an Apple device here at work to test it with. Will investigate next week.
ShortSnow
Post by ShortSnow »
Hm,
blind test(er) :oops: , Sorry!
ShortSnow
Post by ShortSnow »
Folder "Sent Messages" can't deleted in Rainloop. It is automaticly recreated and the it is also created in every Mailbox (only tested Rainloop), not only new Mailboxes.
