Debian10-->11 upgrade PHP Warning! [GELÖST]
Nach dem Aktualisieren von Debian von 10 auf 11 erhalte ich die folgende Fehlermeldung. Die Protokolle beschweren sich über PHP. Die Admin-Oberfläche ist nicht verfügbar. Vielen Dank im Voraus für die Hilfe.
Grüße Anthony_
/var/log/keyhelp/php-error.log 2325/6469 35%[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: MySQL - Connection Error: 2002 (No such file or director[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: DBConnection::query(): Couldn't fetch mysqli in /home/ke[22-May-2022 19:26:01 Europe/Budapest] PHP Warning: mysqli::ping(): Couldn't fetch mysqli in /home/keyhelp/w[22-May-2022 19:26:02 Europe/Budapest] PHP Notice: DB-Connection timed out, now reconnecting... in /home/key[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: mysqli::close(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: MySQL - Connection Error: 2002 (No such file or director[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/[22-May-2022 19:26:02 Europe/Budapest] PHP Warning: mysqli::query(): Couldn't fetch mysqli in /home/keyhelp/ 1Help
Couldn't fetch mysqli inWarning: DBConnection::query(): /var/log/mysql/error.log 1599/1665 96%2022-05-22 9:42:26 21530 [Warning] Aborted connection 21530 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 16:01:38 21469 [Warning] Aborted connection 21469 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 19:25:39 24919 [Warning] Aborted connection 24919 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 19:25:39 24918 [Warning] Aborted connection 24918 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 19:25:39 24920 [Warning] Aborted connection 24920 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 19:25:39 24917 [Warning] Aborted connection 24917 to db: 'keyhelp' user: 'keyhelp' host: 'localhos2022-05-22 19:26:01 0 [Note] /usr/sbin/mysqld (initiated by: unknown): Normal shutdown 2022-05-22 19:26:01 0 [Note] Event Scheduler: Purging the queue. 0 events 2022-05-22 19:26:01 0 [Note] InnoDB: FTS optimize thread exiting. 2022-05-22 19:26:01 0 [Note] InnoDB: Starting shutdown... 2022-05-22 19:26:01 0 [Note] InnoDB: Dumping buffer pool(s) to /var/lib/mysql/ib_buffer_pool 2022-05-22 19:26:01 0 [Note] InnoDB: Buffer pool(s) dump completed at 220522 19:26:01 2022-05-22 19:26:03 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1" 2022-05-22 19:26:03 0 [Note] InnoDB: Shutdown completed; log sequence number
- OlliTheDarkness
Re: Debian10-->11 upgrade PHP Warning!
mal für die Zukunft, nutze zur angemessenen Formatierung die vom Forum bereitgestellten Möglichkeiten.
In deinem Fall für den Log die Code Formatierung, der Button befindet über dem Textfeld und sieht so aus </>.
Bitte , Danke.
Zum Fehler, die DB läuft nicht.
Server bereits neu gestartet ?
Fehler in den Logs ?
Servicestatus des DB Servers ?
Wie hast du das OS Upgrade gemacht? Manuell auf der Konsole oder mithilfe des Keyhelp Upgrade Scripts?
- OlliTheDarkness
Die Frage ist gut, bin automatisch von ausgegangen das er das Script genutzt hat
Wenn nicht erklärt das wieder alles.
Ich sollte aufhören an die Inteligenz der Menschheit zu glauben.
Sorry, aber diese Aussage erschließt sich mir nicht.
Hast du dieses Script benutzt ->
https://www.keyhelp.de/news/upgrade-deb ... debian-11/
Anthony, Serverzeit Budapest, und der Satz oben erschließt sich mir nicht wirklich.
Kann es sein, dass Deutsch nicht Deine Muttersprache ist, Du etwas wie Google Translate benutzt?
Wenn ja wäre eine Kommunikation in Englisch evtl. zielführender.
Re: Debian10-->11 upgrade PHP Warning! [GELÖST]
Man lässt es einmal durchlaufen. Dabei immer die lokalen Konfigurationen behalten.
Dann ein Restart und noch einmal durchlaufen lassen.
Dann ein letzter Restart und Willkommen bei Debian 11.
