Installation on old ubuntu version  [SOLVED]
info@eurhosting.net
Post by info@eurhosting.net »
Any Idea how to install KeyHelp on ubuntu 16?
I am tryng the following, but with no result
wget –no-check-certificate https://install.keyhelp.de/get_keyhelp.php -O install_keyhelp.sh ; bash install_keyhelp.sh ;
wget https://install.keyhelp.de/get_keyhelp.php -O –no-check-certificate install_keyhelp.sh ; bash install_keyhelp.sh ;
I'm running out of options, anyone had the same issue?
I even tried to instal the CA package of course (apt-get install ca-certificates) with no result
Stop stop stop
If hosting is not your main focus, I can be of help to mantain your servers
Re: Installation on old ubuntu version
Why don't you just upgrade to a current version of Ubuntu (or even better the original) before?
KH needs a fresh installation else you will have a lot of manual work.
info@eurhosting.net
24unix wrote: Sun 26. Jun 2022, 18:42 Why don't you just upgrade to a current version of Ubuntu (or even better the original) before?
Customer need ubuntu 16
Running the commandwget without -O will download the file install_keyhelp.sh
But ./install_keyhelp.sh give me
root@borgolab:~# ./install_keyhelp.sh
-bash: ./install_keyhelp.sh: Permission denied
Stop stop stop
info@eurhosting.net wrote: Sun 26. Jun 2022, 18:52
Tell customer to become sane.
chmod +x install_keyhelp.sh. && ./install_keyhelp.sh
or
The installer does not support outdated OS anyway.
The installation will not start.
info@eurhosting.net
Ok, at the end seems that the installation script that we can download with the installer is the last version only and not downloading the suitable one
root@borgolab:~# wget https://install.keyhelp.de/get_keyhelp.php --no-check-certificate -O install_keyhelp.sh ; bash install_keyhelp.sh ;
--2022-06-26 18:56:47--  https://install.keyhelp.de/get_keyhelp.php
Resolving install.keyhelp.de (install.keyhelp.de)... 62.141.56.232, 2001:1b60:2:11:913:101:be57:cafe
Connecting to install.keyhelp.de (install.keyhelp.de)|62.141.56.232|:443... connected.
WARNING: cannot verify install.keyhelp.de's certificate, issued by ‘CN=R3,O=Let's Encrypt,C=US’:
  Issued certificate has expired.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/x-sh]
Saving to: ‘install_keyhelp.sh’
install_keyhelp.sh                      [ <=>                                                               ]  17.59K  --.-KB/s    in 0s
2022-06-26 18:56:47 (38.8 MB/s) - ‘install_keyhelp.sh’ saved [18015]
You are about to install KeyHelp.
Running system checks...
ERROR: Unsupported OS
root@borgolab:~#
So the question persist, how to install old keyhelp version if a customer need an old OS version?
Anyone got the same issue?
Stop stop stop
info@eurhosting.net wrote: Sun 26. Jun 2022, 18:58 Ok, at the end seems that the installation script that we can download with the installer is the last version only and not downloading the suitable one
root@borgolab:~#
Why does the customer need that outdated version?
KeyHelp itself relies on actual software components which were not available in earlier Versions.
This is not an issue, this is a feature!
info@eurhosting.net
I do not see the reason to question customer need, we discuss it already with him and he did not accept a new OS version, so the need is Ubuntu 16, full stop.
Is your habit to questioning with your customers? Mine will simply move to a different supplier if after discussion I will insist to bug them...
Stop stop stop
info@eurhosting.net
Tobi wrote: Sun 26. Jun 2022, 19:04
I acn not belive there is no "old version repo"
Stop stop stop
info@eurhosting.net wrote: Sun 26. Jun 2022, 19:18 I do not see the reason to question customer need, we discuss it already with him and he did not accept a new OS version, so the need is Ubuntu 16, full stop.
An outdated system is a security risk, full stop.
OK, then KH is no option. Full stop.
And, yes, most of my customers have little knowledge of technology, so I ask when they have silly wishes, most of the time the is a better solution.
info@eurhosting.net
24unix wrote: Sun 26. Jun 2022, 19:28
If they doesn't want to pay the framework update I can not force them, not all customers accept a budget modification, unfortunately
Stop stop stop
info@eurhosting.net
Jolinar wrote: Sun 26. Jun 2022, 19:28
Happy to know that your customer pay without questioning, really :)
Stop stop stop
info@eurhosting.net wrote: Sun 26. Jun 2022, 19:34
Which framework update?
You did not say why the customer needs old Ubuntu.
Just that he wants to have it.
If you could give reasons one could argue about.
E.g. Hardware X is only certified with that specific Ubuntu. Then one could think about a solution.
