Login issue - version mismatch  [SOLVED]
rmprdmn
Post by rmprdmn »
(Problems not related to KeyHelp belong in the Offtopic forum)
(e.g. Ubuntu 20.04)
Unknown
22.1 but login page shows "Version mismatch"
Tried to login to control panel but got Version mismatch.
Tried to run update through the terminal - now I have error "Forbidden You don't have permission to access this resource."
Expected result
Actual result
Steps to reproduce
Additional information
(e.g. recent changes to the server, excerpts from log files (/var/log/*, /var/log/keyhelp/php-error.log, etc.))
Re: Login issue - version mismatch
please execute the following command
keyhelp-toolbox
and provide the output of the menu item "7) Show system information",
as well as the latest contents of:
/var/log/keyhelp/cronjob/panel-update.log
rmprdmn
Post by rmprdmn »
CPU                     : Intel Xeon Processor (Skylake, IBRS) (amd64) / Cores 1
System virtualization   : KVM
Server time             : 13:59:08 - July 15, 2022
Uptime                  : Days 0 / Hours 0 / Minutes 52
Server utilization
CPU load                : 1.00 % (0.01 / 0 / 0)
Process count           : 124
Emails in queue         : 0
Disk space              : Free:  1.49 GiB     Used: 12.36 GiB     Total: 14.61 GiB
Memory                  : Free: 469.78 MiB     Used: 482.20 MiB     Total: 951.98 MiB
Swap space              : Free: 847.00 MiB     Used: 177.00 MiB     Total: 1024.00 MiB
Applications
Operating system        : Ubuntu 20.04 (64-bit)
KeyHelp                 : 22.0.1 (DB), 22.1 (File), 2687 (Build)
Kernel                  : Kernel 5.4.0-122-generic
Web server              : Apache 2.4.41
DNS server              : BIND 9.16.1
PHP                     : PHP 7.4.3
Database server         : MariaDB 10.3.34
FTP server              : ProFTPD 1.3.6c
Mail transfer agent     : Postfix 3.4.13
Mail delivery agent     : Dovecot 2.3.7.2
MTA content filter      : Amavisd-new 2.11.0
Spam filter             : SpamAssassin 3.4.4
Virus scanner           : ClamAV 0.103.6
Database administration : phpMyAdmin 5.2.0
Webmail                 : Roundcube 1.5.3
Cryptography            : OpenSSL 1.1.1f
Data transfer           : curl 7.68.0
Backup software         : Restic 0.13.1
Backup data transfer    : Rclone 1.58.1
Pending package manager updates
Update count            : 0
Security update count   : 0
Only have panel-update.log.
P.S. Sorry for asking for help but could not find resolution for the similar issue.
panel-update.log
(113.46 KiB) Downloaded 185 times
Re: Login issue - version mismatch  [SOLVED]
It seems that the database connection was interrupted during the update. This is usually not a problem, as KeyHelp has some self-healing features ;). Normally this would be fixed with the next automatic update run of the control panel, which is done every day at 03:xx.
Unfortunately, due to changes in the panel upgrade routine with 22.1 and because there was a smaller update 22.0.1, the auto-healing feature could not work as expected with this particular update.
EDIT:
I have now re-implemented the self-healing features into version 22.1. So if a server suffers from the same problem, it should now heal itself with the next panel update, which should run on Saturday morning.
The issue was fixed on rmprdmn server.
