Installationsfehler "Email protection error"  [GELÖST]
Tschius
Post by Tschius »
ich habe ein eigenartiges Problem bei der Installation von Keyhelp auf einer frischen VM (4 CPU, 8 GB RAM, 512 GB SSD) und Debian 11.4 (auch frisch heruntergeladen: debian-11.4.0-amd64-netinst.iso):
Bei der Ausführung der KH-Installation wird bei "Email protection" ein Fehler gemeldet und im Log (install.log) steht dazu folgendes:
exec  | su - amavis -s /bin/bash -c 'razor-admin -create'
          nextserver: Bootstrap discovery failed. Giving up.
  [SKIPPED DUE PREVIOUS ERRORS] exec  | su - amavis -s /bin/bash -c 'razor-admin -register'
  [SKIPPED DUE PREVIOUS ERRORS] exec  | usermod -aG amavis clamav
  [SKIPPED DUE PREVIOUS ERRORS] exec  | usermod -aG clamav amavis
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chmod 0640 /etc/amavis/conf.d/50-user
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chown root:amavis /etc/amavis/conf.d/50-user
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service clamav-daemon restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service amavis restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service spamassassin restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable spamassassin
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable clamav-daemon
  [SKIPPED DUE PREVIOUS ERRORS] exec  | grep "^\s*DatabaseCustomURL" /etc/clamav/freshclam.conf || echo "
Gekürzte install.log (komplett war fürs Forum zu viel):
Operating System: Debian 11.4 (64-bit)
  Placeholders
  install.ssh_keys =
  install.nagios =
  install.midnight_commander =
  install.server_setup =
  install.hide_lts_notice =
  install.hostname =
  general.preferred_protocol = ipv4
  system.email = root@***HOSTNAME***
  server.domain = ***HOSTNAME***
  server.current_hostname = ***HOSTNAME***
  server.timezone = Europe/Vienna
  server.fstab = # /etc/fstab: static file system information.
  # Use 'blkid' to print the universally unique identifier for a
  # device; this may be used with UUID= as a more robust way to name devices
  # that works even if disks are added and removed. See fstab(5).
  # systemd generates mount units based on this file, see systemd.mount(5).
  # Please run 'systemctl daemon-reload' after making changes here.
  # <file system> <mount point>   <type>  <options>       <dump>  <pass>
  # / was on /dev/sda2 during installation
  UUID=c0950e04-33e2-4445-ae76-25688d15794f     /     ext4     errors=remount-ro,usrquota,grpquota     0     1
  # /boot/efi was on /dev/sda1 during installation
  UUID=C029-CE4E  /boot/efi       vfat    umask=0077      0       1
  # swap was on /dev/sda3 during installation
  UUID=fee1ec3e-0373-43b5-8484-f89f6de9cf75 none            swap    sw              0       0
  /dev/sr0        /media/cdrom0   udf,iso9660 user,noauto     0       0
  encryption.base = ***KH_ENCRYPTION_BASE***
  webserver.log_format_with_logio = %h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O
  webserver.log_format_without_logio = %h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" 0 0
  webserver.http_port = 80
  webserver.https_port = 443
  webserver.redirect_url_domain_not_found = https://***HOSTNAME***/index.php?page=domain_not_found
  dir.home = /home/keyhelp
  dir.keyhelp = /home/keyhelp/www/keyhelp
  dir.webmail = /home/keyhelp/www/webmail
  dir.roundcube = /home/keyhelp/www/roundcube
  dir.rainloop = /home/keyhelp/www/rainloop
  dir.db-administration = /home/keyhelp/www/db-administration
  dir.phpmyadmin = /home/keyhelp/www/phpmyadmin
  dir.adminer = /home/keyhelp/www/adminer
  dir.statistics = /home/keyhelp/www/kh.webstats
  dir.acme_challenge = /home/keyhelp/www/.well-known/acme-challenge
  dir.autoconfig = /home/keyhelp/www/keyhelp/misc/emailconfig
  email.enable_virus_checks = 1
  dovecot.imap_login_process_limit = 100
  dovecot.max_userip_connections = 10
  dovecot.enforce_quota = 1
  postfix.inet_protocols = ipv4
  clamav.signatures_for_config =
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/junk.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/jurlbl.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/phish.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/rogue.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/sanesecurity.ftm
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/sigwhitelist.ign2
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/scam.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/spamimg.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/spamattach.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/blurl.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/foxhole_generic.cdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/foxhole_filename.cdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/malwarehash.hsb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/hackingteam.hsb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_malware.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_malware_links.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_extended_malware.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow.attachments.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_bad_cw.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_cracked_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_malware_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_phishing_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_malware_attach.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/porcupine.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/phishtank.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/porcupine.hsb
  DatabaseCustomURL https://urlhaus.abuse.ch/downloads/urlhaus.ndb
  php.version = 7.4
  db.tuning_file = tuning.cnf
  db.setup.username = root
  db.setup.password = ***DB_SETUP_PASS***
  db.root.username = root
  db.root.password = ***DB_SETUP_PASS***
  db.keyhelp.host = localhost
  db.keyhelp.username = keyhelp
  db.keyhelp.password = ***DB_KH_PASS***
  db.keyhelp.database = keyhelp
  db.keyhelp_root.host = localhost
  db.keyhelp_root.username = keyhelp_root
  db.keyhelp_root.password = ***DB_KH_ROOT_PASS***
  bind.rname = root.***HOSTNAME***.
  bind.serial = 2022071500
  bind.name_servers.0 = ns.***HOSTNAME***.
  bind.name_servers.1 = ns2.***HOSTNAME***.
  bind.ips_v4.0 = ***IP_0***
  admin.username = keyadmin
  admin.password = ***KH_ADMIN_PASS***
  admin.email = root@***HOSTNAME***
  phpmyadmin.password = ***PMA_PASS***
  phpmyadmin.blowfishsecret = ***PMA_CRYPT***
  roundcube.product_name = KeyHelp Webmail
  roundcube.support_url =
  roundcube.password = ***RC_PASS***
  roundcube.plugins = 'managesieve','password','markasjunk','keyhelp_sync_identities'
  roundcube.plugins_db = managesieve, password, markasjunk, keyhelp_sync_identities
  roundcube.skin = elastic
  roundcube.logo =
  roundcube.logo_login =
  roundcube.logo_favicon =
  roundcube.24_byte_des_key = ***RC_CRYPT***
  roundcube.pw_length = 8
  rainloop.product_name = KeyHelp Webmail
  rainloop.password = ***RL_PASS***
  rainloop.language = de
  keyhelp.id = e019d8618db8d3a9de827d8a250268fe11fdd1b2c921dbb016d585780c06d53d7e967dce5459e0c603985a9662dda60bd63f8cdb45df434f77b1ad1b8bfce9a3
  keyhelp.url = https://***HOSTNAME***
  keyhelp.version = 22.1
  keyhelp.settings.ips = ***IP_0***
  keyhelp.settings.name_servers = ns.***HOSTNAME***.,ns2.***HOSTNAME***.
  keyhelp.language = de
  motd.ip = ***IP_0***
  ftp.tls_required =
  ssh_keys.support_keys =
  firewall.rule_set = common
  Update sources list
  exec  | apt-get update
          OK:1 http://security.debian.org/debian-security bullseye-security InRelease
          OK:2 http://deb.debian.org/debian bullseye InRelease
          OK:3 http://deb.debian.org/debian bullseye-updates InRelease
          Paketlisten werden gelesen…
  Installation requirements
  exec  | apt-get install -y unzip
          Abhängigkeitsbaum wird aufgebaut…
          Statusinformationen werden eingelesen…
          Vorgeschlagene Pakete:
            zip
          Die folgenden NEUEN Pakete werden installiert:
            unzip
          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 171 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 394 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 unzip amd64 6.0-26 [171 kB]
          Es wurden 171 kB in 0 s geholt (2.172 kB/s).
          Vormals nicht ausgewähltes Paket unzip wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 5%
(Lese Datenbank ... 10%
(Lese Datenbank ... 15%
(Lese Datenbank ... 20%
(Lese Datenbank ... 25%
(Lese Datenbank ... 30%
(Lese Datenbank ... 35%
(Lese Datenbank ... 40%
(Lese Datenbank ... 45%
(Lese Datenbank ... 50%
(Lese Datenbank ... 55%
(Lese Datenbank ... 60%
(Lese Datenbank ... 65%
(Lese Datenbank ... 70%
(Lese Datenbank ... 75%
(Lese Datenbank ... 80%
(Lese Datenbank ... 85%
(Lese Datenbank ... 90%
(Lese Datenbank ... 95%
(Lese Datenbank ... 100%
(Lese Datenbank ... 22014 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../unzip_6.0-26_amd64.deb ...
          Entpacken von unzip (6.0-26) ...
          unzip (6.0-26) wird eingerichtet ...
          Trigger für mailcap (3.69) werden verarbeitet ...
  exec  | apt-get install -y zip
            zip
          Es müssen 232 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 638 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 zip amd64 3.0-12 [232 kB]
          Es wurden 232 kB in 0 s geholt (2.678 kB/s).
          Vormals nicht ausgewähltes Paket zip wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 22032 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../archives/zip_3.0-12_amd64.deb ...
          Entpacken von zip (3.0-12) ...
          zip (3.0-12) wird eingerichtet ...
  exec  | apt-get install -y bzip2
          bzip2 ist schon die neueste Version (1.0.8-4).
          bzip2 wurde als manuell installiert festgelegt.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
  Sudo
  exec  | apt-get install -y sudo
            sudo
          Es müssen 1.059 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 4.699 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 sudo amd64 1.9.5p2-3 [1.059 kB]
          Es wurden 1.059 kB in 0 s geholt (8.679 kB/s).
          Vormals nicht ausgewähltes Paket sudo wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 22047 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../sudo_1.9.5p2-3_amd64.deb ...
          Entpacken von sudo (1.9.5p2-3) ...
          sudo (1.9.5p2-3) wird eingerichtet ...
  Firewall
  exec  | apt-get install -y iptables
          Die folgenden zusätzlichen Pakete werden installiert:
            libip6tc2 libnetfilter-conntrack3 libnfnetlink0
            firewalld
            iptables libip6tc2 libnetfilter-conntrack3 libnfnetlink0
          0 aktualisiert, 4 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 472 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 2.850 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 libip6tc2 amd64 1.8.7-1 [35,0 kB]
          Holen:2 http://deb.debian.org/debian bullseye/main amd64 libnfnetlink0 amd64 1.0.1-3+b1 [13,9 kB]
          Holen:3 http://deb.debian.org/debian bullseye/main amd64 libnetfilter-conntrack3 amd64 1.0.8-3 [40,6 kB]
          Holen:4 http://deb.debian.org/debian bullseye/main amd64 iptables amd64 1.8.7-1 [382 kB]
          Es wurden 472 kB in 0 s geholt (2.431 kB/s).
          Vormals nicht ausgewähltes Paket libip6tc2:amd64 wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 34903 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../libip6tc2_1.8.7-1_amd64.deb ...
          Entpacken von libip6tc2:amd64 (1.8.7-1) ...
          Vormals nicht ausgewähltes Paket libnfnetlink0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../libnfnetlink0_1.0.1-3+b1_amd64.deb ...
          Entpacken von libnfnetlink0:amd64 (1.0.1-3+b1) ...
          Vormals nicht ausgewähltes Paket libnetfilter-conntrack3:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../libnetfilter-conntrack3_1.0.8-3_amd64.deb ...
          Entpacken von libnetfilter-conntrack3:amd64 (1.0.8-3) ...
          Vormals nicht ausgewähltes Paket iptables wird gewählt.
          Vorbereitung zum Entpacken von .../iptables_1.8.7-1_amd64.deb ...
          Entpacken von iptables (1.8.7-1) ...
          libip6tc2:amd64 (1.8.7-1) wird eingerichtet ...
          libnfnetlink0:amd64 (1.0.1-3+b1) wird eingerichtet ...
          libnetfilter-conntrack3:amd64 (1.0.8-3) wird eingerichtet ...
          iptables (1.8.7-1) wird eingerichtet ...
          update-alternatives: /usr/sbin/iptables-legacy wird verwendet, um /usr/sbin/iptables (iptables) im automatischen Modus bereitzustellen
          update-alternatives: /usr/sbin/ip6tables-legacy wird verwendet, um /usr/sbin/ip6tables (ip6tables) im automatischen Modus bereitzustellen
          update-alternatives: /usr/sbin/iptables-nft wird verwendet, um /usr/sbin/iptables (iptables) im automatischen Modus bereitzustellen
          update-alternatives: /usr/sbin/ip6tables-nft wird verwendet, um /usr/sbin/ip6tables (ip6tables) im automatischen Modus bereitzustellen
          update-alternatives: /usr/sbin/arptables-nft wird verwendet, um /usr/sbin/arptables (arptables) im automatischen Modus bereitzustellen
          update-alternatives: /usr/sbin/ebtables-nft wird verwendet, um /usr/sbin/ebtables (ebtables) im automatischen Modus bereitzustellen
          Trigger für man-db (2.9.4-2) werden verarbeitet ...
          Trigger für libc-bin (2.31-13+deb11u3) werden verarbeitet ...
  exec  | mkdir -p -m 0700 /etc/keyhelp/iptables/
  exec  | apt-get install -y nftables
          nftables ist schon die neueste Version (0.9.8-3.1).
  exec  | mkdir -p -m 0755 /etc/nftables/
  files | firewall/rules_ipv4_common => /etc/keyhelp/iptables/startup_rules_ipv4
  files | firewall/rules_ipv6_common => /etc/keyhelp/iptables/startup_rules_ipv6
  files | nftables/nftables.conf => /etc/nftables.conf
  files | nftables/fail2ban.conf => /etc/nftables/fail2ban.conf
  exec  | chown keyhelp:keyhelp -R /etc/keyhelp/iptables/
  exec  | nft -f /etc/nftables/fail2ban.conf
  import | /home/keyhelp/www/keyhelp/install/templates/firewall/common.sql => keyhelp
  SSH
  exec  | apt-get install -y openssh-server
            openssh-sftp-server runit-helper
            molly-guard monkeysphere ssh-askpass ufw
            openssh-server openssh-sftp-server runit-helper
          0 aktualisiert, 3 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 446 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 1.765 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 openssh-sftp-server amd64 1:8.4p1-5+deb11u1 [52,4 kB]
          Holen:2 http://deb.debian.org/debian bullseye/main amd64 runit-helper all 2.10.3 [7.808 B]
          Holen:3 http://deb.debian.org/debian bullseye/main amd64 openssh-server amd64 1:8.4p1-5+deb11u1 [385 kB]
          Vorkonfiguration der Pakete ...
          Es wurden 446 kB in 0 s geholt (2.386 kB/s).
          Vormals nicht ausgewähltes Paket openssh-sftp-server wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 35123 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../openssh-sftp-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
          Entpacken von openssh-sftp-server (1:8.4p1-5+deb11u1) ...
          Vormals nicht ausgewähltes Paket runit-helper wird gewählt.
          Vorbereitung zum Entpacken von .../runit-helper_2.10.3_all.deb ...
          Entpacken von runit-helper (2.10.3) ...
          Vormals nicht ausgewähltes Paket openssh-server wird gewählt.
          Vorbereitung zum Entpacken von .../openssh-server_1%3a8.4p1-5+deb11u1_amd64.deb ...
          Entpacken von openssh-server (1:8.4p1-5+deb11u1) ...
          runit-helper (2.10.3) wird eingerichtet ...
          openssh-sftp-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
          openssh-server (1:8.4p1-5+deb11u1) wird eingerichtet ...
          Creating config file /etc/ssh/sshd_config with new version
          Creating SSH2 RSA key; this may take some time ...
          3072 SHA256:jSUf/4U/6a2nMpMx9EQZQ19GA5xbKsZqoSbOfeWMCBM root@server07 (RSA)
          Creating SSH2 ECDSA key; this may take some time ...
          256 SHA256:4rwIgokRxYdqk9OeqNtZzFaT5DHLXTPcVCA4JlrQT6U root@server07 (ECDSA)
          Creating SSH2 ED25519 key; this may take some time ...
          256 SHA256:AOZUfx7K9aGzcV729R/I0q8FjOybPQEamYKfWkwAAJI root@server07 (ED25519)
          Created symlink /etc/systemd/system/sshd.service → /lib/systemd/system/ssh.service.
          Created symlink /etc/systemd/system/multi-user.target.wants/ssh.service → /lib/systemd/system/ssh.service.
          rescue-ssh.target is a disabled or a static unit, not starting it.
  exec  | grep --quiet "^\s*DenyGroups keyhelp_nossh keyhelp_suspended" /etc/ssh/sshd_config || printf "\n# Limit KeyHelp usergroup\nDenyGroups keyhelp_nossh keyhelp_suspended\n" >> /etc/ssh/sshd_config
  exec  | grep --quiet "^\s*Match Group keyhelp_chroot" /etc/ssh/sshd_config || printf "\nMatch Group keyhelp_chroot\n ChrootDirectory %%h\n AllowTCPForwarding no\n X11Forwarding no\nMatch all\n" >> /etc/ssh/sshd_config
  exec  | service ssh restart
  Email protection
  exec  | apt-get install -y amavis clamav clamav-daemon spamassassin pyzor razor
            altermime binutils binutils-common binutils-x86-64-linux-gnu clamav-base
            clamav-freshclam clamdscan cpp cpp-10 dirmngr gcc gcc-10 gnupg gnupg-l10n
            gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm
            libarchive-zip-perl libasan6 libassuan0 libatomic1 libauthen-sasl-perl
            libberkeleydb-perl libbinutils libc-dev-bin libc-devtools libc6-dev libcc1-0
            libclamav9 libcommon-sense-perl libconvert-binhex-perl libconvert-tnef-perl
            libconvert-uulib-perl libcrypt-dev libcrypt-openssl-bignum-perl
            libcrypt-openssl-random-perl libcrypt-openssl-rsa-perl libctf-nobfd0 libctf0
            libdata-dump-perl libdigest-bubblebabble-perl libdigest-hmac-perl
            liberror-perl libfile-listing-perl libfont-afm-perl libgcc-10-dev
            libhtml-form-perl libhtml-format-perl libhtml-tree-perl libhttp-cookies-perl
            libhttp-daemon-perl libhttp-negotiate-perl libio-multiplex-perl
            libio-socket-inet6-perl libio-socket-ssl-perl libio-stringy-perl libisl23
            libitm1 libjson-perl libjson-xs-perl libksba8 liblsan0
            liblwp-protocol-https-perl libmail-authenticationresults-perl
            libmail-dkim-perl libmail-spf-perl libmailtools-perl libmime-tools-perl
            libmpc3 libmspack0 libnet-cidr-lite-perl libnet-cidr-perl libnet-dns-perl
            libnet-dns-sec-perl libnet-http-perl libnet-ip-perl libnet-libidn-perl
            libnet-patricia-perl libnet-server-perl libnet-smtp-ssl-perl
            libnet-snmp-perl libnet-ssleay-perl libnetaddr-ip-perl libnpth0 libnsl-dev
            libperl4-corelibs-perl libquadmath0 libsocket6-perl
            libsys-hostname-long-perl libtfm1 libtirpc-dev libtry-tiny-perl libtsan0
            libtypes-serialiser-perl libubsan1 libunix-syslog-perl libwww-perl
            libwww-robotrules-perl linux-libc-dev make manpages-dev pax
            perl-openssl-defaults pinentry-curses re2c sa-compile spamc
            arj cabextract dspam lhasa libnet-ldap-perl libsnmp-perl libzeromq-perl lzop
            nomarch p7zip rpm unrar binutils-doc libclamunrar clamav-docs daemon cpp-doc
            gcc-10-locales dbus-user-session pinentry-gnome3 tor gcc-multilib autoconf
            automake libtool flex bison gdb gcc-doc gcc-10-multilib gcc-10-doc
            parcimonie xloadimage scdaemon libgssapi-perl glibc-doc libclamunrar9
            libcrypt-ssleay-perl liblog-log4perl-perl libcrypt-des-perl
            libauthen-ntlm-perl make-doc pinentry-doc pyzor-doc libencode-detect-perl
            libgeoip2-perl libbsd-resource-perl
          Empfohlene Pakete:
            ripole
            altermime amavisd-new binutils binutils-common binutils-x86-64-linux-gnu
            clamav clamav-base clamav-daemon clamav-freshclam clamdscan cpp cpp-10
            dirmngr gcc gcc-10 gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client
            gpg-wks-server gpgconf gpgsm libarchive-zip-perl libasan6 libassuan0
            libatomic1 libauthen-sasl-perl libberkeleydb-perl libbinutils libc-dev-bin
            libc-devtools libc6-dev libcc1-0 libclamav9 libcommon-sense-perl
            libconvert-binhex-perl libconvert-tnef-perl libconvert-uulib-perl
            libcrypt-dev libcrypt-openssl-bignum-perl libcrypt-openssl-random-perl
            libcrypt-openssl-rsa-perl libctf-nobfd0 libctf0 libdata-dump-perl
            libdigest-bubblebabble-perl libdigest-hmac-perl liberror-perl
            libfile-listing-perl libfont-afm-perl libgcc-10-dev libhtml-form-perl
            perl-openssl-defaults pinentry-curses pyzor razor re2c sa-compile
            spamassassin spamc
          0 aktualisiert, 117 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Es müssen 63,0 MB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 219 MB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 libarchive-zip-perl all 1.68-1 [104 kB]
          Holen:2 http://deb.debian.org/debian bullseye/main amd64 libberkeleydb-perl amd64 0.64-1+b1 [124 kB]
          Holen:3 http://deb.debian.org/debian bullseye/main amd64 libio-stringy-perl all 2.111-3 [56,5 kB]
          Holen:4 http://deb.debian.org/debian bullseye/main amd64 libconvert-binhex-perl all 1.125-1 [30,5 kB]
          Holen:5 http://deb.debian.org/debian bullseye/main amd64 perl-openssl-defaults amd64 5 [7.360 B]
          Holen:6 http://deb.debian.org/debian bullseye/main amd64 libnet-ssleay-perl amd64 1.88-3+b1 [321 kB]
          Holen:7 http://deb.debian.org/debian bullseye/main amd64 libio-socket-ssl-perl all 2.069-1 [215 kB]
          Holen:8 http://deb.debian.org/debian bullseye/main amd64 libnet-smtp-ssl-perl all 1.04-1 [6.184 B]
          Holen:9 http://deb.debian.org/debian bullseye/main amd64 libmailtools-perl all 2.21-1 [95,5 kB]
          Holen:10 http://deb.debian.org/debian bullseye/main amd64 libmime-tools-perl all 5.509-1 [212 kB]
          Holen:11 http://deb.debian.org/debian bullseye/main amd64 libconvert-tnef-perl all 0.18-1.1 [24,5 kB]
          Holen:12 http://deb.debian.org/debian bullseye/main amd64 libconvert-uulib-perl amd64 1:1.5~dfsg-1+b3 [99,4 kB]
          Holen:13 http://deb.debian.org/debian bullseye/main amd64 libcrypt-openssl-bignum-perl amd64 0.09-1+b3 [25,9 kB]
          Holen:14 http://deb.debian.org/debian bullseye/main amd64 libcrypt-openssl-random-perl amd64 0.15-2+b1 [11,4 kB]
          Holen:15 http://deb.debian.org/debian bullseye/main amd64 libcrypt-openssl-rsa-perl amd64 0.31-1+b3 [26,1 kB]
          Holen:16 http://deb.debian.org/debian bullseye/main amd64 liberror-perl all 0.17029-1 [31,0 kB]
          Holen:17 http://deb.debian.org/debian bullseye/main amd64 libjson-perl all 4.03000-1 [88,6 kB]
          Holen:18 http://deb.debian.org/debian bullseye/main amd64 libmail-authenticationresults-perl all 2.20210112-1 [41,5 kB]
          Holen:19 http://deb.debian.org/debian bullseye/main amd64 libdigest-hmac-perl all 1.03+dfsg-2.1 [10,8 kB]
          Holen:20 http://deb.debian.org/debian bullseye/main amd64 libnet-ip-perl all 1.26-2 [29,0 kB]
          Holen:21 http://deb.debian.org/debian bullseye/main amd64 libnet-dns-perl all 1.29-1 [380 kB]
          Holen:22 http://deb.debian.org/debian bullseye/main amd64 libmail-dkim-perl all 1.20200907-1 [166 kB]
          Holen:23 http://deb.debian.org/debian bullseye/main amd64 libnet-libidn-perl amd64 0.12.ds-3+b3 [18,8 kB]
          Holen:24 http://deb.debian.org/debian bullseye/main amd64 libio-multiplex-perl all 1.16-1.1 [22,0 kB]
          Holen:25 http://deb.debian.org/debian bullseye/main amd64 libsocket6-perl amd64 0.29-1+b3 [24,4 kB]
          Holen:26 http://deb.debian.org/debian bullseye/main amd64 libio-socket-inet6-perl all 2.72-2.1 [16,8 kB]
          Holen:27 http://deb.debian.org/debian bullseye/main amd64 libnet-cidr-perl all 0.20-1 [15,1 kB]
          Holen:28 http://deb.debian.org/debian bullseye/main amd64 libnet-server-perl all 2.009-2 [179 kB]
          Holen:29 http://deb.debian.org/debian bullseye/main amd64 libunix-syslog-perl amd64 1.1-3+b3 [22,8 kB]
          Holen:30 http://deb.debian.org/debian bullseye/main amd64 libnet-snmp-perl all 6.0.1-6 [94,6 kB]
          Holen:31 http://deb.debian.org/debian bullseye/main amd64 pax amd64 1:20201030-1 [84,3 kB]
          Holen:32 http://deb.debian.org/debian bullseye/main amd64 amavisd-new all 1:2.11.1-5 [937 kB]
          Holen:33 http://deb.debian.org/debian bullseye/main amd64 altermime amd64 0.3.10-12 [60,3 kB]
          Holen:34 http://deb.debian.org/debian bullseye/main amd64 binutils-common amd64 2.35.2-2 [2.220 kB]
          Holen:35 http://deb.debian.org/debian bullseye/main amd64 libbinutils amd64 2.35.2-2 [570 kB]
          Holen:36 http://deb.debian.org/debian bullseye/main amd64 libctf-nobfd0 amd64 2.35.2-2 [110 kB]
          Holen:37 http://deb.debian.org/debian bullseye/main amd64 libctf0 amd64 2.35.2-2 [53,2 kB]
          Holen:38 http://deb.debian.org/debian bullseye/main amd64 binutils-x86-64-linux-gnu amd64 2.35.2-2 [1.809 kB]
          Holen:39 http://deb.debian.org/debian bullseye/main amd64 binutils amd64 2.35.2-2 [61,2 kB]
          Holen:40 http://deb.debian.org/debian bullseye/main amd64 clamav-base all 0.103.6+dfsg-0+deb11u1 [129 kB]
          Holen:41 http://deb.debian.org/debian bullseye/main amd64 libmspack0 amd64 0.10.1-2 [50,3 kB]
          Holen:42 http://deb.debian.org/debian bullseye/main amd64 libtfm1 amd64 0.13-4 [60,5 kB]
          Holen:43 http://deb.debian.org/debian bullseye/main amd64 libclamav9 amd64 0.103.6+dfsg-0+deb11u1 [880 kB]
          Holen:44 http://deb.debian.org/debian bullseye/main amd64 clamav-freshclam amd64 0.103.6+dfsg-0+deb11u1 [180 kB]
          Holen:45 http://deb.debian.org/debian bullseye/main amd64 clamav amd64 0.103.6+dfsg-0+deb11u1 [181 kB]
          Holen:46 http://deb.debian.org/debian bullseye/main amd64 clamav-daemon amd64 0.103.6+dfsg-0+deb11u1 [257 kB]
          Holen:47 http://deb.debian.org/debian bullseye/main amd64 clamdscan amd64 0.103.6+dfsg-0+deb11u1 [105 kB]
          Holen:48 http://deb.debian.org/debian bullseye/main amd64 libisl23 amd64 0.23-1 [676 kB]
          Holen:49 http://deb.debian.org/debian bullseye/main amd64 libmpc3 amd64 1.2.0-1 [45,0 kB]
          Holen:50 http://deb.debian.org/debian bullseye/main amd64 cpp-10 amd64 10.2.1-6 [8.528 kB]
          Holen:51 http://deb.debian.org/debian bullseye/main amd64 cpp amd64 4:10.2.1-1 [19,7 kB]
          Holen:52 http://deb.debian.org/debian bullseye/main amd64 libassuan0 amd64 2.5.3-7.1 [50,5 kB]
          Holen:53 http://deb.debian.org/debian bullseye/main amd64 gpgconf amd64 2.2.27-2+deb11u2 [548 kB]
          Holen:54 http://deb.debian.org/debian bullseye/main amd64 libksba8 amd64 1.5.0-3 [123 kB]
          Holen:55 http://deb.debian.org/debian bullseye/main amd64 libnpth0 amd64 1.6-3 [19,0 kB]
          Holen:56 http://deb.debian.org/debian bullseye/main amd64 dirmngr amd64 2.2.27-2+deb11u2 [763 kB]
          Holen:57 http://deb.debian.org/debian bullseye/main amd64 libcc1-0 amd64 10.2.1-6 [47,0 kB]
          Holen:58 http://deb.debian.org/debian bullseye/main amd64 libitm1 amd64 10.2.1-6 [25,8 kB]
          Holen:59 http://deb.debian.org/debian bullseye/main amd64 libatomic1 amd64 10.2.1-6 [9.008 B]
          Holen:60 http://deb.debian.org/debian bullseye/main amd64 libasan6 amd64 10.2.1-6 [2.065 kB]
          Holen:61 http://deb.debian.org/debian bullseye/main amd64 liblsan0 amd64 10.2.1-6 [828 kB]
          Holen:62 http://deb.debian.org/debian bullseye/main amd64 libtsan0 amd64 10.2.1-6 [2.000 kB]
          Holen:63 http://deb.debian.org/debian bullseye/main amd64 libubsan1 amd64 10.2.1-6 [777 kB]
          Holen:64 http://deb.debian.org/debian bullseye/main amd64 libquadmath0 amd64 10.2.1-6 [145 kB]
          Holen:65 http://deb.debian.org/debian bullseye/main amd64 libgcc-10-dev amd64 10.2.1-6 [2.328 kB]
          Holen:66 http://deb.debian.org/debian bullseye/main amd64 gcc-10 amd64 10.2.1-6 [17,0 MB]
          Holen:67 http://deb.debian.org/debian bullseye/main amd64 gcc amd64 4:10.2.1-1 [5.192 B]
          Holen:68 http://deb.debian.org/debian bullseye/main amd64 gnupg-l10n all 2.2.27-2+deb11u2 [1.086 kB]
          Holen:69 http://deb.debian.org/debian bullseye/main amd64 gnupg-utils amd64 2.2.27-2+deb11u2 [905 kB]
          Holen:70 http://deb.debian.org/debian bullseye/main amd64 gpg amd64 2.2.27-2+deb11u2 [928 kB]
          Holen:71 http://deb.debian.org/debian bullseye/main amd64 pinentry-curses amd64 1.1.0-4 [64,9 kB]
          Holen:72 http://deb.debian.org/debian bullseye/main amd64 gpg-agent amd64 2.2.27-2+deb11u2 [669 kB]
          Holen:73 http://deb.debian.org/debian bullseye/main amd64 gpg-wks-client amd64 2.2.27-2+deb11u2 [524 kB]
          Holen:74 http://deb.debian.org/debian bullseye/main amd64 gpg-wks-server amd64 2.2.27-2+deb11u2 [516 kB]
          Holen:75 http://deb.debian.org/debian bullseye/main amd64 gpgsm amd64 2.2.27-2+deb11u2 [645 kB]
          Holen:76 http://deb.debian.org/debian bullseye/main amd64 gnupg all 2.2.27-2+deb11u2 [825 kB]
          Holen:77 http://deb.debian.org/debian bullseye/main amd64 libauthen-sasl-perl all 2.1600-1.1 [45,4 kB]
          Holen:78 http://deb.debian.org/debian bullseye/main amd64 libc-dev-bin amd64 2.31-13+deb11u3 [275 kB]
          Holen:79 http://deb.debian.org/debian bullseye/main amd64 libc-devtools amd64 2.31-13+deb11u3 [245 kB]
          Holen:80 http://deb.debian.org/debian bullseye/main amd64 linux-libc-dev amd64 5.10.127-1 [1.516 kB]
          Holen:81 http://deb.debian.org/debian bullseye/main amd64 libcrypt-dev amd64 1:4.4.18-4 [104 kB]
          Holen:82 http://deb.debian.org/debian bullseye/main amd64 libtirpc-dev amd64 1.3.1-1 [190 kB]
          Holen:83 http://deb.debian.org/debian bullseye/main amd64 libnsl-dev amd64 1.3.0-2 [66,4 kB]
          Holen:84 http://deb.debian.org/debian bullseye/main amd64 libc6-dev amd64 2.31-13+deb11u3 [2.348 kB]
          Holen:85 http://deb.debian.org/debian bullseye/main amd64 libcommon-sense-perl amd64 3.75-1+b4 [24,6 kB]
          Holen:86 http://deb.debian.org/debian bullseye/main amd64 libdata-dump-perl all 1.23-1.1 [27,6 kB]
          Holen:87 http://deb.debian.org/debian bullseye/main amd64 libdigest-bubblebabble-perl all 0.02-2.1 [7.472 B]
          Holen:88 http://deb.debian.org/debian bullseye/main amd64 libfile-listing-perl all 6.14-1 [12,4 kB]
          Holen:89 http://deb.debian.org/debian bullseye/main amd64 libfont-afm-perl all 1.20-3 [14,0 kB]
          Holen:90 http://deb.debian.org/debian bullseye/main amd64 libhtml-form-perl all 6.07-1 [22,9 kB]
          Holen:91 http://deb.debian.org/debian bullseye/main amd64 libhtml-tree-perl all 5.07-2 [213 kB]
          Holen:92 http://deb.debian.org/debian bullseye/main amd64 libhtml-format-perl all 2.12-1.1 [43,8 kB]
          Holen:93 http://deb.debian.org/debian bullseye/main amd64 libhttp-cookies-perl all 6.10-1 [19,6 kB]
          Holen:94 http://deb.debian.org/debian bullseye/main amd64 libhttp-daemon-perl all 6.12-1 [22,9 kB]
          Holen:95 http://deb.debian.org/debian bullseye/main amd64 libhttp-negotiate-perl all 6.01-1 [12,8 kB]
          Holen:96 http://deb.debian.org/debian bullseye/main amd64 libtypes-serialiser-perl all 1.01-1 [12,2 kB]
          Holen:97 http://deb.debian.org/debian bullseye/main amd64 libjson-xs-perl amd64 4.030-1+b1 [94,9 kB]
          Holen:98 http://deb.debian.org/debian bullseye/main amd64 libnet-http-perl all 6.20-1 [25,1 kB]
          Holen:99 http://deb.debian.org/debian bullseye/main amd64 libtry-tiny-perl all 0.30-1 [23,3 kB]
          Holen:100 http://deb.debian.org/debian bullseye/main amd64 libwww-robotrules-perl all 6.02-1 [12,9 kB]
          Holen:101 http://deb.debian.org/debian bullseye/main amd64 libwww-perl all 6.52-1 [192 kB]
          Holen:102 http://deb.debian.org/debian bullseye/main amd64 liblwp-protocol-https-perl all 6.10-1 [12,2 kB]
          Holen:103 http://deb.debian.org/debian bullseye/main amd64 libnetaddr-ip-perl amd64 4.079+dfsg-1+b5 [104 kB]
          Holen:104 http://deb.debian.org/debian bullseye/main amd64 libmail-spf-perl all 2.9.0-5 [121 kB]
          Holen:105 http://deb.debian.org/debian bullseye/main amd64 libnet-cidr-lite-perl all 0.22-1 [14,8 kB]
          Holen:106 http://deb.debian.org/debian bullseye/main amd64 libnet-dns-sec-perl amd64 1.18-1+b1 [54,1 kB]
          Holen:107 http://deb.debian.org/debian bullseye/main amd64 libnet-patricia-perl amd64 1.22-1+b7 [29,4 kB]
          Holen:108 http://deb.debian.org/debian bullseye/main amd64 libperl4-corelibs-perl all 0.004-2 [38,4 kB]
          Holen:109 http://deb.debian.org/debian bullseye/main amd64 libsys-hostname-long-perl all 1.5-2 [11,8 kB]
          Holen:110 http://deb.debian.org/debian bullseye/main amd64 make amd64 4.3-4.1 [396 kB]
          Holen:111 http://deb.debian.org/debian bullseye/main amd64 manpages-dev all 5.10-1 [2.309 kB]
          Holen:112 http://deb.debian.org/debian bullseye/main amd64 pyzor all 1:1.0.0-6 [37,9 kB]
          Holen:113 http://deb.debian.org/debian bullseye/main amd64 razor amd64 1:2.85-4.2+b7 [108 kB]
          Holen:114 http://deb.debian.org/debian bullseye/main amd64 re2c amd64 2.0.3-1 [344 kB]
          Holen:115 http://deb.debian.org/debian bullseye/main amd64 spamassassin all 3.4.6-1 [1.256 kB]
          Holen:116 http://deb.debian.org/debian bullseye/main amd64 sa-compile all 3.4.6-1 [66,4 kB]
          Holen:117 http://deb.debian.org/debian bullseye/main amd64 spamc amd64 3.4.6-1 [101 kB]
          Es wurden 63,0 MB in 12 s geholt (5.369 kB/s).
          Vormals nicht ausgewähltes Paket libarchive-zip-perl wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 36776 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../000-libarchive-zip-perl_1.68-1_all.deb ...
          Entpacken von libarchive-zip-perl (1.68-1) ...
          Vormals nicht ausgewähltes Paket libberkeleydb-perl:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../001-libberkeleydb-perl_0.64-1+b1_amd64.deb ...
          Entpacken von libberkeleydb-perl:amd64 (0.64-1+b1) ...
          Vormals nicht ausgewähltes Paket libio-stringy-perl wird gewählt.
          Vorbereitung zum Entpacken von .../002-libio-stringy-perl_2.111-3_all.deb ...
          Entpacken von libio-stringy-perl (2.111-3) ...
          Vormals nicht ausgewähltes Paket libconvert-binhex-perl wird gewählt.
          Vorbereitung zum Entpacken von .../003-libconvert-binhex-perl_1.125-1_all.deb ...
          Entpacken von libconvert-binhex-perl (1.125-1) ...
          Vormals nicht ausgewähltes Paket perl-openssl-defaults:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../004-perl-openssl-defaults_5_amd64.deb ...
          Entpacken von perl-openssl-defaults:amd64 (5) ...
          Vormals nicht ausgewähltes Paket libnet-ssleay-perl wird gewählt.
          Vorbereitung zum Entpacken von .../005-libnet-ssleay-perl_1.88-3+b1_amd64.deb ...
          Entpacken von libnet-ssleay-perl (1.88-3+b1) ...
          Vormals nicht ausgewähltes Paket libio-socket-ssl-perl wird gewählt.
          Vorbereitung zum Entpacken von .../006-libio-socket-ssl-perl_2.069-1_all.deb ...
          Entpacken von libio-socket-ssl-perl (2.069-1) ...
          Vormals nicht ausgewähltes Paket libnet-smtp-ssl-perl wird gewählt.
          Vorbereitung zum Entpacken von .../007-libnet-smtp-ssl-perl_1.04-1_all.deb ...
          Entpacken von libnet-smtp-ssl-perl (1.04-1) ...
          Vormals nicht ausgewähltes Paket libmailtools-perl wird gewählt.
          Vorbereitung zum Entpacken von .../008-libmailtools-perl_2.21-1_all.deb ...
          Entpacken von libmailtools-perl (2.21-1) ...
          Vormals nicht ausgewähltes Paket libmime-tools-perl wird gewählt.
          Vorbereitung zum Entpacken von .../009-libmime-tools-perl_5.509-1_all.deb ...
          Entpacken von libmime-tools-perl (5.509-1) ...
          Vormals nicht ausgewähltes Paket libconvert-tnef-perl wird gewählt.
          Vorbereitung zum Entpacken von .../010-libconvert-tnef-perl_0.18-1.1_all.deb ...
          Entpacken von libconvert-tnef-perl (0.18-1.1) ...
          Vormals nicht ausgewähltes Paket libconvert-uulib-perl wird gewählt.
          Vorbereitung zum Entpacken von .../011-libconvert-uulib-perl_1%3a1.5~dfsg-1+b3_amd64.deb ...
          Entpacken von libconvert-uulib-perl (1:1.5~dfsg-1+b3) ...
          Vormals nicht ausgewähltes Paket libcrypt-openssl-bignum-perl wird gewählt.
          Vorbereitung zum Entpacken von .../012-libcrypt-openssl-bignum-perl_0.09-1+b3_amd64.deb ...
          Entpacken von libcrypt-openssl-bignum-perl (0.09-1+b3) ...
          Vormals nicht ausgewähltes Paket libcrypt-openssl-random-perl wird gewählt.
          Vorbereitung zum Entpacken von .../013-libcrypt-openssl-random-perl_0.15-2+b1_amd64.deb ...
          Entpacken von libcrypt-openssl-random-perl (0.15-2+b1) ...
          Vormals nicht ausgewähltes Paket libcrypt-openssl-rsa-perl wird gewählt.
          Vorbereitung zum Entpacken von .../014-libcrypt-openssl-rsa-perl_0.31-1+b3_amd64.deb ...
          Entpacken von libcrypt-openssl-rsa-perl (0.31-1+b3) ...
          Vormals nicht ausgewähltes Paket liberror-perl wird gewählt.
          Vorbereitung zum Entpacken von .../015-liberror-perl_0.17029-1_all.deb ...
          Entpacken von liberror-perl (0.17029-1) ...
          Vormals nicht ausgewähltes Paket libjson-perl wird gewählt.
          Vorbereitung zum Entpacken von .../016-libjson-perl_4.03000-1_all.deb ...
          Entpacken von libjson-perl (4.03000-1) ...
          Vormals nicht ausgewähltes Paket libmail-authenticationresults-perl wird gewählt.
          Vorbereitung zum Entpacken von .../017-libmail-authenticationresults-perl_2.20210112-1_all.deb ...
          Entpacken von libmail-authenticationresults-perl (2.20210112-1) ...
          Vormals nicht ausgewähltes Paket libdigest-hmac-perl wird gewählt.
          Vorbereitung zum Entpacken von .../018-libdigest-hmac-perl_1.03+dfsg-2.1_all.deb ...
          Entpacken von libdigest-hmac-perl (1.03+dfsg-2.1) ...
          Vormals nicht ausgewähltes Paket libnet-ip-perl wird gewählt.
          Vorbereitung zum Entpacken von .../019-libnet-ip-perl_1.26-2_all.deb ...
          Entpacken von libnet-ip-perl (1.26-2) ...
          Vormals nicht ausgewähltes Paket libnet-dns-perl wird gewählt.
          Vorbereitung zum Entpacken von .../020-libnet-dns-perl_1.29-1_all.deb ...
          Entpacken von libnet-dns-perl (1.29-1) ...
          Vormals nicht ausgewähltes Paket libmail-dkim-perl wird gewählt.
          Vorbereitung zum Entpacken von .../021-libmail-dkim-perl_1.20200907-1_all.deb ...
          Entpacken von libmail-dkim-perl (1.20200907-1) ...
          Vormals nicht ausgewähltes Paket libnet-libidn-perl wird gewählt.
          Vorbereitung zum Entpacken von .../022-libnet-libidn-perl_0.12.ds-3+b3_amd64.deb ...
          Entpacken von libnet-libidn-perl (0.12.ds-3+b3) ...
          Vormals nicht ausgewähltes Paket libio-multiplex-perl wird gewählt.
          Vorbereitung zum Entpacken von .../023-libio-multiplex-perl_1.16-1.1_all.deb ...
          Entpacken von libio-multiplex-perl (1.16-1.1) ...
          Vormals nicht ausgewähltes Paket libsocket6-perl wird gewählt.
          Vorbereitung zum Entpacken von .../024-libsocket6-perl_0.29-1+b3_amd64.deb ...
          Entpacken von libsocket6-perl (0.29-1+b3) ...
          Vormals nicht ausgewähltes Paket libio-socket-inet6-perl wird gewählt.
          Vorbereitung zum Entpacken von .../025-libio-socket-inet6-perl_2.72-2.1_all.deb ...
          Entpacken von libio-socket-inet6-perl (2.72-2.1) ...
          Vormals nicht ausgewähltes Paket libnet-cidr-perl wird gewählt.
          Vorbereitung zum Entpacken von .../026-libnet-cidr-perl_0.20-1_all.deb ...
          Entpacken von libnet-cidr-perl (0.20-1) ...
          Vormals nicht ausgewähltes Paket libnet-server-perl wird gewählt.
          Vorbereitung zum Entpacken von .../027-libnet-server-perl_2.009-2_all.deb ...
          Entpacken von libnet-server-perl (2.009-2) ...
          Vormals nicht ausgewähltes Paket libunix-syslog-perl wird gewählt.
          Vorbereitung zum Entpacken von .../028-libunix-syslog-perl_1.1-3+b3_amd64.deb ...
          Entpacken von libunix-syslog-perl (1.1-3+b3) ...
          Vormals nicht ausgewähltes Paket libnet-snmp-perl wird gewählt.
          Vorbereitung zum Entpacken von .../029-libnet-snmp-perl_6.0.1-6_all.deb ...
          Entpacken von libnet-snmp-perl (6.0.1-6) ...
          Vormals nicht ausgewähltes Paket pax wird gewählt.
          Vorbereitung zum Entpacken von .../030-pax_1%3a20201030-1_amd64.deb ...
          Entpacken von pax (1:20201030-1) ...
          Vormals nicht ausgewähltes Paket amavisd-new wird gewählt.
          Vorbereitung zum Entpacken von .../031-amavisd-new_1%3a2.11.1-5_all.deb ...
          Entpacken von amavisd-new (1:2.11.1-5) ...
          Vormals nicht ausgewähltes Paket altermime wird gewählt.
          Vorbereitung zum Entpacken von .../032-altermime_0.3.10-12_amd64.deb ...
          Entpacken von altermime (0.3.10-12) ...
          Vormals nicht ausgewähltes Paket binutils-common:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../033-binutils-common_2.35.2-2_amd64.deb ...
          Entpacken von binutils-common:amd64 (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket libbinutils:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../034-libbinutils_2.35.2-2_amd64.deb ...
          Entpacken von libbinutils:amd64 (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket libctf-nobfd0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../035-libctf-nobfd0_2.35.2-2_amd64.deb ...
          Entpacken von libctf-nobfd0:amd64 (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket libctf0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../036-libctf0_2.35.2-2_amd64.deb ...
          Entpacken von libctf0:amd64 (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket binutils-x86-64-linux-gnu wird gewählt.
          Vorbereitung zum Entpacken von .../037-binutils-x86-64-linux-gnu_2.35.2-2_amd64.deb ...
          Entpacken von binutils-x86-64-linux-gnu (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket binutils wird gewählt.
          Vorbereitung zum Entpacken von .../038-binutils_2.35.2-2_amd64.deb ...
          Entpacken von binutils (2.35.2-2) ...
          Vormals nicht ausgewähltes Paket clamav-base wird gewählt.
          Vorbereitung zum Entpacken von .../039-clamav-base_0.103.6+dfsg-0+deb11u1_all.deb ...
          Entpacken von clamav-base (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket libmspack0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../040-libmspack0_0.10.1-2_amd64.deb ...
          Entpacken von libmspack0:amd64 (0.10.1-2) ...
          Vormals nicht ausgewähltes Paket libtfm1:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../041-libtfm1_0.13-4_amd64.deb ...
          Entpacken von libtfm1:amd64 (0.13-4) ...
          Vormals nicht ausgewähltes Paket libclamav9:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../042-libclamav9_0.103.6+dfsg-0+deb11u1_amd64.deb ...
          Entpacken von libclamav9:amd64 (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket clamav-freshclam wird gewählt.
          Vorbereitung zum Entpacken von .../043-clamav-freshclam_0.103.6+dfsg-0+deb11u1_amd64.deb ...
          Entpacken von clamav-freshclam (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket clamav wird gewählt.
          Vorbereitung zum Entpacken von .../044-clamav_0.103.6+dfsg-0+deb11u1_amd64.deb ...
          Entpacken von clamav (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket clamav-daemon wird gewählt.
          Vorbereitung zum Entpacken von .../045-clamav-daemon_0.103.6+dfsg-0+deb11u1_amd64.deb ...
          Entpacken von clamav-daemon (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket clamdscan wird gewählt.
          Vorbereitung zum Entpacken von .../046-clamdscan_0.103.6+dfsg-0+deb11u1_amd64.deb ...
          Entpacken von clamdscan (0.103.6+dfsg-0+deb11u1) ...
          Vormals nicht ausgewähltes Paket libisl23:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../047-libisl23_0.23-1_amd64.deb ...
          Entpacken von libisl23:amd64 (0.23-1) ...
          Vormals nicht ausgewähltes Paket libmpc3:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../048-libmpc3_1.2.0-1_amd64.deb ...
          Entpacken von libmpc3:amd64 (1.2.0-1) ...
          Vormals nicht ausgewähltes Paket cpp-10 wird gewählt.
          Vorbereitung zum Entpacken von .../049-cpp-10_10.2.1-6_amd64.deb ...
          Entpacken von cpp-10 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket cpp wird gewählt.
          Vorbereitung zum Entpacken von .../050-cpp_4%3a10.2.1-1_amd64.deb ...
          Entpacken von cpp (4:10.2.1-1) ...
          Vormals nicht ausgewähltes Paket libassuan0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../051-libassuan0_2.5.3-7.1_amd64.deb ...
          Entpacken von libassuan0:amd64 (2.5.3-7.1) ...
          Vormals nicht ausgewähltes Paket gpgconf wird gewählt.
          Vorbereitung zum Entpacken von .../052-gpgconf_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpgconf (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket libksba8:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../053-libksba8_1.5.0-3_amd64.deb ...
          Entpacken von libksba8:amd64 (1.5.0-3) ...
          Vormals nicht ausgewähltes Paket libnpth0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../054-libnpth0_1.6-3_amd64.deb ...
          Entpacken von libnpth0:amd64 (1.6-3) ...
          Vormals nicht ausgewähltes Paket dirmngr wird gewählt.
          Vorbereitung zum Entpacken von .../055-dirmngr_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von dirmngr (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket libcc1-0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../056-libcc1-0_10.2.1-6_amd64.deb ...
          Entpacken von libcc1-0:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libitm1:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../057-libitm1_10.2.1-6_amd64.deb ...
          Entpacken von libitm1:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libatomic1:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../058-libatomic1_10.2.1-6_amd64.deb ...
          Entpacken von libatomic1:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libasan6:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../059-libasan6_10.2.1-6_amd64.deb ...
          Entpacken von libasan6:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket liblsan0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../060-liblsan0_10.2.1-6_amd64.deb ...
          Entpacken von liblsan0:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libtsan0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../061-libtsan0_10.2.1-6_amd64.deb ...
          Entpacken von libtsan0:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libubsan1:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../062-libubsan1_10.2.1-6_amd64.deb ...
          Entpacken von libubsan1:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libquadmath0:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../063-libquadmath0_10.2.1-6_amd64.deb ...
          Entpacken von libquadmath0:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket libgcc-10-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../064-libgcc-10-dev_10.2.1-6_amd64.deb ...
          Entpacken von libgcc-10-dev:amd64 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket gcc-10 wird gewählt.
          Vorbereitung zum Entpacken von .../065-gcc-10_10.2.1-6_amd64.deb ...
          Entpacken von gcc-10 (10.2.1-6) ...
          Vormals nicht ausgewähltes Paket gcc wird gewählt.
          Vorbereitung zum Entpacken von .../066-gcc_4%3a10.2.1-1_amd64.deb ...
          Entpacken von gcc (4:10.2.1-1) ...
          Vormals nicht ausgewähltes Paket gnupg-l10n wird gewählt.
          Vorbereitung zum Entpacken von .../067-gnupg-l10n_2.2.27-2+deb11u2_all.deb ...
          Entpacken von gnupg-l10n (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gnupg-utils wird gewählt.
          Vorbereitung zum Entpacken von .../068-gnupg-utils_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gnupg-utils (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gpg wird gewählt.
          Vorbereitung zum Entpacken von .../069-gpg_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpg (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket pinentry-curses wird gewählt.
          Vorbereitung zum Entpacken von .../070-pinentry-curses_1.1.0-4_amd64.deb ...
          Entpacken von pinentry-curses (1.1.0-4) ...
          Vormals nicht ausgewähltes Paket gpg-agent wird gewählt.
          Vorbereitung zum Entpacken von .../071-gpg-agent_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpg-agent (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gpg-wks-client wird gewählt.
          Vorbereitung zum Entpacken von .../072-gpg-wks-client_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpg-wks-client (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gpg-wks-server wird gewählt.
          Vorbereitung zum Entpacken von .../073-gpg-wks-server_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpg-wks-server (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gpgsm wird gewählt.
          Vorbereitung zum Entpacken von .../074-gpgsm_2.2.27-2+deb11u2_amd64.deb ...
          Entpacken von gpgsm (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket gnupg wird gewählt.
          Vorbereitung zum Entpacken von .../075-gnupg_2.2.27-2+deb11u2_all.deb ...
          Entpacken von gnupg (2.2.27-2+deb11u2) ...
          Vormals nicht ausgewähltes Paket libauthen-sasl-perl wird gewählt.
          Vorbereitung zum Entpacken von .../076-libauthen-sasl-perl_2.1600-1.1_all.deb ...
          Entpacken von libauthen-sasl-perl (2.1600-1.1) ...
          Vormals nicht ausgewähltes Paket libc-dev-bin wird gewählt.
          Vorbereitung zum Entpacken von .../077-libc-dev-bin_2.31-13+deb11u3_amd64.deb ...
          Entpacken von libc-dev-bin (2.31-13+deb11u3) ...
          Vormals nicht ausgewähltes Paket libc-devtools wird gewählt.
          Vorbereitung zum Entpacken von .../078-libc-devtools_2.31-13+deb11u3_amd64.deb ...
          Entpacken von libc-devtools (2.31-13+deb11u3) ...
          Vormals nicht ausgewähltes Paket linux-libc-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../079-linux-libc-dev_5.10.127-1_amd64.deb ...
          Entpacken von linux-libc-dev:amd64 (5.10.127-1) ...
          Vormals nicht ausgewähltes Paket libcrypt-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../080-libcrypt-dev_1%3a4.4.18-4_amd64.deb ...
          Entpacken von libcrypt-dev:amd64 (1:4.4.18-4) ...
          Vormals nicht ausgewähltes Paket libtirpc-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../081-libtirpc-dev_1.3.1-1_amd64.deb ...
          Entpacken von libtirpc-dev:amd64 (1.3.1-1) ...
          Vormals nicht ausgewähltes Paket libnsl-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../082-libnsl-dev_1.3.0-2_amd64.deb ...
          Entpacken von libnsl-dev:amd64 (1.3.0-2) ...
          Vormals nicht ausgewähltes Paket libc6-dev:amd64 wird gewählt.
          Vorbereitung zum Entpacken von .../083-libc6-dev_2.31-13+deb11u3_amd64.deb ...
          Entpacken von libc6-dev:amd64 (2.31-13+deb11u3) ...
          Vormals nicht ausgewähltes Paket libcommon-sense-perl wird gewählt.
          Vorbereitung zum Entpacken von .../084-libcommon-sense-perl_3.75-1+b4_amd64.deb ...
          Entpacken von libcommon-sense-perl (3.75-1+b4) ...
          Vormals nicht ausgewähltes Paket libdata-dump-perl wird gewählt.
          Vorbereitung zum Entpacken von .../085-libdata-dump-perl_1.23-1.1_all.deb ...
          Entpacken von libdata-dump-perl (1.23-1.1) ...
          Vormals nicht ausgewähltes Paket libdigest-bubblebabble-perl wird gewählt.
          Vorbereitung zum Entpacken von .../086-libdigest-bubblebabble-perl_0.02-2.1_all.deb ...
          Entpacken von libdigest-bubblebabble-perl (0.02-2.1) ...
          Vormals nicht ausgewähltes Paket libfile-listing-perl wird gewählt.
          Vorbereitung zum Entpacken von .../087-libfile-listing-perl_6.14-1_all.deb ...
          Entpacken von libfile-listing-perl (6.14-1) ...
          Vormals nicht ausgewähltes Paket libfont-afm-perl wird gewählt.
          Vorbereitung zum Entpacken von .../088-libfont-afm-perl_1.20-3_all.deb ...
          Entpacken von libfont-afm-perl (1.20-3) ...
          Vormals nicht ausgewähltes Paket libhtml-form-perl wird gewählt.
          Vorbereitung zum Entpacken von .../089-libhtml-form-perl_6.07-1_all.deb ...
          Entpacken von libhtml-form-perl (6.07-1) ...
          Vormals nicht ausgewähltes Paket libhtml-tree-perl wird gewählt.
          Vorbereitung zum Entpacken von .../090-libhtml-tree-perl_5.07-2_all.deb ...
          Entpacken von libhtml-tree-perl (5.07-2) ...
          Vormals nicht ausgewähltes Paket libhtml-format-perl wird gewählt.
          Vorbereitung zum Entpacken von .../091-libhtml-format-perl_2.12-1.1_all.deb ...
          Entpacken von libhtml-format-perl (2.12-1.1) ...
          Vormals nicht ausgewähltes Paket libhttp-cookies-perl wird gewählt.
          Vorbereitung zum Entpacken von .../092-libhttp-cookies-perl_6.10-1_all.deb ...
          Entpacken von libhttp-cookies-perl (6.10-1) ...
          Vormals nicht ausgewähltes Paket libhttp-daemon-perl wird gewählt.
          Vorbereitung zum Entpacken von .../093-libhttp-daemon-perl_6.12-1_all.deb ...
          Entpacken von libhttp-daemon-perl (6.12-1) ...
          Vormals nicht ausgewähltes Paket libhttp-negotiate-perl wird gewählt.
          Vorbereitung zum Entpacken von .../094-libhttp-negotiate-perl_6.01-1_all.deb ...
          Entpacken von libhttp-negotiate-perl (6.01-1) ...
          Vormals nicht ausgewähltes Paket libtypes-serialiser-perl wird gewählt.
          Vorbereitung zum Entpacken von .../095-libtypes-serialiser-perl_1.01-1_all.deb ...
          Entpacken von libtypes-serialiser-perl (1.01-1) ...
          Vormals nicht ausgewähltes Paket libjson-xs-perl wird gewählt.
          Vorbereitung zum Entpacken von .../096-libjson-xs-perl_4.030-1+b1_amd64.deb ...
          Entpacken von libjson-xs-perl (4.030-1+b1) ...
          Vormals nicht ausgewähltes Paket libnet-http-perl wird gewählt.
          Vorbereitung zum Entpacken von .../097-libnet-http-perl_6.20-1_all.deb ...
          Entpacken von libnet-http-perl (6.20-1) ...
          Vormals nicht ausgewähltes Paket libtry-tiny-perl wird gewählt.
          Vorbereitung zum Entpacken von .../098-libtry-tiny-perl_0.30-1_all.deb ...
          Entpacken von libtry-tiny-perl (0.30-1) ...
          Vormals nicht ausgewähltes Paket libwww-robotrules-perl wird gewählt.
          Vorbereitung zum Entpacken von .../099-libwww-robotrules-perl_6.02-1_all.deb ...
          Entpacken von libwww-robotrules-perl (6.02-1) ...
          Vormals nicht ausgewähltes Paket libwww-perl wird gewählt.
          Vorbereitung zum Entpacken von .../100-libwww-perl_6.52-1_all.deb ...
          Entpacken von libwww-perl (6.52-1) ...
          Vormals nicht ausgewähltes Paket liblwp-protocol-https-perl wird gewählt.
          Vorbereitung zum Entpacken von .../101-liblwp-protocol-https-perl_6.10-1_all.deb ...
          Entpacken von liblwp-protocol-https-perl (6.10-1) ...
          Vormals nicht ausgewähltes Paket libnetaddr-ip-perl wird gewählt.
          Vorbereitung zum Entpacken von .../102-libnetaddr-ip-perl_4.079+dfsg-1+b5_amd64.deb ...
          Entpacken von libnetaddr-ip-perl (4.079+dfsg-1+b5) ...
          Vormals nicht ausgewähltes Paket libmail-spf-perl wird gewählt.
          Vorbereitung zum Entpacken von .../103-libmail-spf-perl_2.9.0-5_all.deb ...
          Entpacken von libmail-spf-perl (2.9.0-5) ...
          Vormals nicht ausgewähltes Paket libnet-cidr-lite-perl wird gewählt.
          Vorbereitung zum Entpacken von .../104-libnet-cidr-lite-perl_0.22-1_all.deb ...
          Entpacken von libnet-cidr-lite-perl (0.22-1) ...
          Vormals nicht ausgewähltes Paket libnet-dns-sec-perl wird gewählt.
          Vorbereitung zum Entpacken von .../105-libnet-dns-sec-perl_1.18-1+b1_amd64.deb ...
          Entpacken von libnet-dns-sec-perl (1.18-1+b1) ...
          Vormals nicht ausgewähltes Paket libnet-patricia-perl wird gewählt.
          Vorbereitung zum Entpacken von .../106-libnet-patricia-perl_1.22-1+b7_amd64.deb ...
          Entpacken von libnet-patricia-perl (1.22-1+b7) ...
          Vormals nicht ausgewähltes Paket libperl4-corelibs-perl wird gewählt.
          Vorbereitung zum Entpacken von .../107-libperl4-corelibs-perl_0.004-2_all.deb ...
          Entpacken von libperl4-corelibs-perl (0.004-2) ...
          Vormals nicht ausgewähltes Paket libsys-hostname-long-perl wird gewählt.
          Vorbereitung zum Entpacken von .../108-libsys-hostname-long-perl_1.5-2_all.deb ...
          Entpacken von libsys-hostname-long-perl (1.5-2) ...
          Vormals nicht ausgewähltes Paket make wird gewählt.
          Vorbereitung zum Entpacken von .../109-make_4.3-4.1_amd64.deb ...
          Entpacken von make (4.3-4.1) ...
          Vormals nicht ausgewähltes Paket manpages-dev wird gewählt.
          Vorbereitung zum Entpacken von .../110-manpages-dev_5.10-1_all.deb ...
          Entpacken von manpages-dev (5.10-1) ...
          Vormals nicht ausgewähltes Paket pyzor wird gewählt.
          Vorbereitung zum Entpacken von .../111-pyzor_1%3a1.0.0-6_all.deb ...
          Entpacken von pyzor (1:1.0.0-6) ...
          Vormals nicht ausgewähltes Paket razor wird gewählt.
          Vorbereitung zum Entpacken von .../112-razor_1%3a2.85-4.2+b7_amd64.deb ...
          Entpacken von razor (1:2.85-4.2+b7) ...
          Vormals nicht ausgewähltes Paket re2c wird gewählt.
          Vorbereitung zum Entpacken von .../113-re2c_2.0.3-1_amd64.deb ...
          Entpacken von re2c (2.0.3-1) ...
          Vormals nicht ausgewähltes Paket spamassassin wird gewählt.
          Vorbereitung zum Entpacken von .../114-spamassassin_3.4.6-1_all.deb ...
          Entpacken von spamassassin (3.4.6-1) ...
          Vormals nicht ausgewähltes Paket sa-compile wird gewählt.
          Vorbereitung zum Entpacken von .../115-sa-compile_3.4.6-1_all.deb ...
          Entpacken von sa-compile (3.4.6-1) ...
          Vormals nicht ausgewähltes Paket spamc wird gewählt.
          Vorbereitung zum Entpacken von .../116-spamc_3.4.6-1_amd64.deb ...
          Entpacken von spamc (3.4.6-1) ...
          libksba8:amd64 (1.5.0-3) wird eingerichtet ...
          libberkeleydb-perl:amd64 (0.64-1+b1) wird eingerichtet ...
          manpages-dev (5.10-1) wird eingerichtet ...
          libhttp-negotiate-perl (6.01-1) wird eingerichtet ...
          libnet-cidr-lite-perl (0.22-1) wird eingerichtet ...
          libfile-listing-perl (6.14-1) wird eingerichtet ...
          libfont-afm-perl (1.20-3) wird eingerichtet ...
          libhttp-cookies-perl (6.10-1) wird eingerichtet ...
          libarchive-zip-perl (1.68-1) wird eingerichtet ...
          pyzor (1:1.0.0-6) wird eingerichtet ...
          libio-stringy-perl (2.111-3) wird eingerichtet ...
          libnet-snmp-perl (6.0.1-6) wird eingerichtet ...
          libauthen-sasl-perl (2.1600-1.1) wird eingerichtet ...
          libhtml-tree-perl (5.07-2) wird eingerichtet ...
          libnet-cidr-perl (0.20-1) wird eingerichtet ...
          libconvert-binhex-perl (1.125-1) wird eingerichtet ...
          libperl4-corelibs-perl (0.004-2) wird eingerichtet ...
          libmspack0:amd64 (0.10.1-2) wird eingerichtet ...
          libtfm1:amd64 (0.13-4) wird eingerichtet ...
          binutils-common:amd64 (2.35.2-2) wird eingerichtet ...
          libtry-tiny-perl (0.30-1) wird eingerichtet ...
          perl-openssl-defaults:amd64 (5) wird eingerichtet ...
          libcommon-sense-perl (3.75-1+b4) wird eingerichtet ...
          linux-libc-dev:amd64 (5.10.127-1) wird eingerichtet ...
          libctf-nobfd0:amd64 (2.35.2-2) wird eingerichtet ...
          libnet-http-perl (6.20-1) wird eingerichtet ...
          libnpth0:amd64 (1.6-3) wird eingerichtet ...
          libhtml-format-perl (2.12-1.1) wird eingerichtet ...
          libassuan0:amd64 (2.5.3-7.1) wird eingerichtet ...
          libclamav9:amd64 (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          libasan6:amd64 (10.2.1-6) wird eingerichtet ...
          liberror-perl (0.17029-1) wird eingerichtet ...
          pax (1:20201030-1) wird eingerichtet ...
          libnetaddr-ip-perl (4.079+dfsg-1+b5) wird eingerichtet ...
          libtirpc-dev:amd64 (1.3.1-1) wird eingerichtet ...
          libio-multiplex-perl (1.16-1.1) wird eingerichtet ...
          libdata-dump-perl (1.23-1.1) wird eingerichtet ...
          make (4.3-4.1) wird eingerichtet ...
          gnupg-l10n (2.2.27-2+deb11u2) wird eingerichtet ...
          libdigest-hmac-perl (1.03+dfsg-2.1) wird eingerichtet ...
          libcrypt-openssl-bignum-perl (0.09-1+b3) wird eingerichtet ...
          libsocket6-perl (0.29-1+b3) wird eingerichtet ...
          libnet-libidn-perl (0.12.ds-3+b3) wird eingerichtet ...
          libquadmath0:amd64 (10.2.1-6) wird eingerichtet ...
          libmpc3:amd64 (1.2.0-1) wird eingerichtet ...
          libatomic1:amd64 (10.2.1-6) wird eingerichtet ...
          libubsan1:amd64 (10.2.1-6) wird eingerichtet ...
          spamc (3.4.6-1) wird eingerichtet ...
          libwww-robotrules-perl (6.02-1) wird eingerichtet ...
          libtypes-serialiser-perl (1.01-1) wird eingerichtet ...
          libcrypt-openssl-random-perl (0.15-2+b1) wird eingerichtet ...
          libhttp-daemon-perl (6.12-1) wird eingerichtet ...
          libnsl-dev:amd64 (1.3.0-2) wird eingerichtet ...
          libcrypt-dev:amd64 (1:4.4.18-4) wird eingerichtet ...
          libjson-perl (4.03000-1) wird eingerichtet ...
          gpgconf (2.2.27-2+deb11u2) wird eingerichtet ...
          libunix-syslog-perl (1.1-3+b3) wird eingerichtet ...
          altermime (0.3.10-12) wird eingerichtet ...
          libcrypt-openssl-rsa-perl (0.31-1+b3) wird eingerichtet ...
          re2c (2.0.3-1) wird eingerichtet ...
          libbinutils:amd64 (2.35.2-2) wird eingerichtet ...
          libisl23:amd64 (0.23-1) wird eingerichtet ...
          libc-dev-bin (2.31-13+deb11u3) wird eingerichtet ...
          libnet-ip-perl (1.26-2) wird eingerichtet ...
          libsys-hostname-long-perl (1.5-2) wird eingerichtet ...
          libconvert-uulib-perl (1:1.5~dfsg-1+b3) wird eingerichtet ...
          libcc1-0:amd64 (10.2.1-6) wird eingerichtet ...
          gpg (2.2.27-2+deb11u2) wird eingerichtet ...
          liblsan0:amd64 (10.2.1-6) wird eingerichtet ...
          cpp-10 (10.2.1-6) wird eingerichtet ...
          libitm1:amd64 (10.2.1-6) wird eingerichtet ...
          libc-devtools (2.31-13+deb11u3) wird eingerichtet ...
          gnupg-utils (2.2.27-2+deb11u2) wird eingerichtet ...
          libhtml-form-perl (6.07-1) wird eingerichtet ...
          libtsan0:amd64 (10.2.1-6) wird eingerichtet ...
          libdigest-bubblebabble-perl (0.02-2.1) wird eingerichtet ...
          clamav-base (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          id: „clamav“: Einen solchen Benutzer gibt es nicht
          libctf0:amd64 (2.35.2-2) wird eingerichtet ...
          libnet-ssleay-perl (1.88-3+b1) wird eingerichtet ...
          pinentry-curses (1.1.0-4) wird eingerichtet ...
          libjson-xs-perl (4.030-1+b1) wird eingerichtet ...
          gpg-agent (2.2.27-2+deb11u2) wird eingerichtet ...
          Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-browser.socket → /usr/lib/systemd/user/gpg-agent-browser.socket.
          Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-extra.socket → /usr/lib/systemd/user/gpg-agent-extra.socket.
          Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent-ssh.socket → /usr/lib/systemd/user/gpg-agent-ssh.socket.
          Created symlink /etc/systemd/user/sockets.target.wants/gpg-agent.socket → /usr/lib/systemd/user/gpg-agent.socket.
          libnet-patricia-perl (1.22-1+b7) wird eingerichtet ...
          libmail-authenticationresults-perl (2.20210112-1) wird eingerichtet ...
          libgcc-10-dev:amd64 (10.2.1-6) wird eingerichtet ...
          gpgsm (2.2.27-2+deb11u2) wird eingerichtet ...
          libnet-dns-perl (1.29-1) wird eingerichtet ...
          libio-socket-inet6-perl (2.72-2.1) wird eingerichtet ...
          dirmngr (2.2.27-2+deb11u2) wird eingerichtet ...
          Created symlink /etc/systemd/user/sockets.target.wants/dirmngr.socket → /usr/lib/systemd/user/dirmngr.socket.
          razor (1:2.85-4.2+b7) wird eingerichtet ...
          clamav-freshclam (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          Created symlink /etc/systemd/system/multi-user.target.wants/clamav-freshclam.service → /lib/systemd/system/clamav-freshclam.service.
          libmail-spf-perl (2.9.0-5) wird eingerichtet ...
          gpg-wks-server (2.2.27-2+deb11u2) wird eingerichtet ...
          clamdscan (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          cpp (4:10.2.1-1) wird eingerichtet ...
          libc6-dev:amd64 (2.31-13+deb11u3) wird eingerichtet ...
          clamav-daemon (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          Created symlink /etc/systemd/system/multi-user.target.wants/clamav-daemon.service → /lib/systemd/system/clamav-daemon.service.
          libio-socket-ssl-perl (2.069-1) wird eingerichtet ...
          binutils-x86-64-linux-gnu (2.35.2-2) wird eingerichtet ...
          gpg-wks-client (2.2.27-2+deb11u2) wird eingerichtet ...
          libnet-dns-sec-perl (1.18-1+b1) wird eingerichtet ...
          binutils (2.35.2-2) wird eingerichtet ...
          clamav (0.103.6+dfsg-0+deb11u1) wird eingerichtet ...
          libnet-server-perl (2.009-2) wird eingerichtet ...
          libnet-smtp-ssl-perl (1.04-1) wird eingerichtet ...
          libmailtools-perl (2.21-1) wird eingerichtet ...
          gcc-10 (10.2.1-6) wird eingerichtet ...
          gnupg (2.2.27-2+deb11u2) wird eingerichtet ...
          libmail-dkim-perl (1.20200907-1) wird eingerichtet ...
          libmime-tools-perl (5.509-1) wird eingerichtet ...
          gcc (4:10.2.1-1) wird eingerichtet ...
          libconvert-tnef-perl (0.18-1.1) wird eingerichtet ...
          amavisd-new (1:2.11.1-5) wird eingerichtet ...
          Creating/updating amavis user account...
          Created symlink /etc/systemd/system/multi-user.target.wants/amavis.service → /lib/systemd/system/amavis.service.
          amavis-mc.service is a disabled or a static unit, not starting it.
          amavisd-snmp-subagent.service is a disabled or a static unit, not starting it.
          liblwp-protocol-https-perl (6.10-1) wird eingerichtet ...
          libwww-perl (6.52-1) wird eingerichtet ...
          spamassassin (3.4.6-1) wird eingerichtet ...
          Lege Systembenutzer »debian-spamd« (UID 117) an ...
          Lege neue Gruppe »debian-spamd« (GID 123) an ...
          Lege neuen Benutzer »debian-spamd« (UID 117) mit Gruppe »debian-spamd« an ...
          Erstelle Home-Verzeichnis »/var/lib/spamassassin« nicht.
          spamassassin.service is a disabled or a static unit, not starting it.
          sa-compile (3.4.6-1) wird eingerichtet ...
          Running sa-compile (may take a long time)
  exec  | mkdir -p -m 0755 /var/spool/spamassassin/
  exec  | chown amavis:amavis /var/spool/spamassassin/
  files | amavis/15-content_filter_mode.twig => /etc/amavis/conf.d/15-content_filter_mode
  files | amavis/50-user.twig => /etc/amavis/conf.d/50-user
  files | spamassassin/spamassassin => /etc/default/spamassassin
  files | spamassassin/local.cf => /etc/spamassassin/local.cf
  exec  | su - amavis -s /bin/bash -c 'razor-admin -create'
          nextserver: Bootstrap discovery failed. Giving up.
  [SKIPPED DUE PREVIOUS ERRORS] exec  | su - amavis -s /bin/bash -c 'razor-admin -register'
  [SKIPPED DUE PREVIOUS ERRORS] exec  | usermod -aG amavis clamav
  [SKIPPED DUE PREVIOUS ERRORS] exec  | usermod -aG clamav amavis
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chmod 0640 /etc/amavis/conf.d/50-user
  [SKIPPED DUE PREVIOUS ERRORS] exec  | chown root:amavis /etc/amavis/conf.d/50-user
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service clamav-daemon restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service amavis restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | service spamassassin restart
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable spamassassin
  [SKIPPED DUE PREVIOUS ERRORS] exec  | systemctl enable clamav-daemon
  [SKIPPED DUE PREVIOUS ERRORS] exec  | grep "^\s*DatabaseCustomURL" /etc/clamav/freshclam.conf || echo "
  " >> /etc/clamav/freshclam.conf
  Fail2ban
  exec  | apt-get install -y fail2ban
            python3-pyinotify python3-systemd whois
            mailx monit sqlite3 python-pyinotify-doc
            fail2ban python3-pyinotify python3-systemd whois
          Es müssen 596 kB an Archiven heruntergeladen werden.
          Nach dieser Operation werden 2.819 kB Plattenplatz zusätzlich benutzt.
          Holen:1 http://deb.debian.org/debian bullseye/main amd64 fail2ban all 0.11.2-2 [451 kB]
          Holen:2 http://deb.debian.org/debian bullseye/main amd64 python3-pyinotify all 0.9.6-1.3 [27,2 kB]
          Holen:3 http://deb.debian.org/debian bullseye/main amd64 python3-systemd amd64 234-3+b4 [36,4 kB]
          Holen:4 http://deb.debian.org/debian bullseye/main amd64 whois amd64 5.5.10 [81,1 kB]
          Es wurden 596 kB in 0 s geholt (2.755 kB/s).
          Vormals nicht ausgewähltes Paket fail2ban wird gewählt.
          (Lese Datenbank ...
(Lese Datenbank ... 44785 Dateien und Verzeichnisse sind derzeit installiert.)
          Vorbereitung zum Entpacken von .../fail2ban_0.11.2-2_all.deb ...
          Entpacken von fail2ban (0.11.2-2) ...
          Vormals nicht ausgewähltes Paket python3-pyinotify wird gewählt.
          Vorbereitung zum Entpacken von .../python3-pyinotify_0.9.6-1.3_all.deb ...
          Entpacken von python3-pyinotify (0.9.6-1.3) ...
          Vormals nicht ausgewähltes Paket python3-systemd wird gewählt.
          Vorbereitung zum Entpacken von .../python3-systemd_234-3+b4_amd64.deb ...
          Entpacken von python3-systemd (234-3+b4) ...
          Vormals nicht ausgewähltes Paket whois wird gewählt.
          Vorbereitung zum Entpacken von .../whois_5.5.10_amd64.deb ...
          Entpacken von whois (5.5.10) ...
          whois (5.5.10) wird eingerichtet ...
          fail2ban (0.11.2-2) wird eingerichtet ...
          Created symlink /etc/systemd/system/multi-user.target.wants/fail2ban.service → /lib/systemd/system/fail2ban.service.
          python3-pyinotify (0.9.6-1.3) wird eingerichtet ...
          python3-systemd (234-3+b4) wird eingerichtet ...
  files | fail2ban/jail.d/keyhelp.local => /etc/fail2ban/jail.d/keyhelp.local
  files | fail2ban/filter.d/keyhelp-phpmyadmin.conf => /etc/fail2ban/filter.d/keyhelp-phpmyadmin.conf
  exec  | chown keyhelp:keyhelp /etc/fail2ban/jail.d/keyhelp.local
  exec  | service fail2ban restart
=> Errors occurred during installation. <=
Ich habe mittlerweile 3x die VM neu aufgesetzt (zum Schluss schon die Minimalstinstallation, ohne irgendwas dazu zu installieren) - es kommt immer exakt derselbe Fehler.
Forum und Google haben mir leider nicht weitergeholfen.
Hat jemand eine Idee dazu, was da schief laufen könnte?
LG Tschius
Re: Installationsfehler "Email protection error"
ich vermute es handelt sich um ein IPv6 only System?
viewtopic.php?t=11222
Tschius
Post by Tschius »
Hallo Alexander,
leider nein - es handelt sich eigentlich eigentlich um ein IPv4 only System.
ifconfig:
root@server07:~# /sbin/ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.114  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::215:5dff:fe03:9a26  prefixlen 64  scopeid 0x20<link>
        ether 00:15:5d:03:9a:26  txqueuelen 1000  (Ethernet)
        RX packets 3107187  bytes 357206548 (340.6 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 11061  bytes 2109910 (2.0 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Lokale Schleife)
        RX packets 5826  bytes 367614 (358.9 KiB)
        TX packets 5826  bytes 367614 (358.9 KiB)
Bevor die Frage zu IPv6 aufkommt: ich bekomme von Provider keine IPv6 zugeteilt - daher konfiguriere ich dahingehend auch nichts.
LG Tschius
Tschius wrote:leider nein - es handelt sich eigentlich eigentlich um ein IPv4 only System.
Okay, umso besser. In dem Fall einfach handelte es sich wohl nur um eine temporäre nicht Erreichbarkeit der razor Server.
Du hast nun 2 Möglichkeiten:
1. Möglichkeit)
Der Fehler verursachenden Befehl und anschließend die mit mit "SKIPPED DUE PREVIOUS ERRORS" markierten ausführen:
Also diese hier:
su - amavis -s /bin/bash -c 'razor-admin -create' ;
su - amavis -s /bin/bash -c 'razor-admin -register' ;
usermod -aG amavis clamav ;
usermod -aG clamav amavis ;
chmod 0640 /etc/amavis/conf.d/50-user ;
chown root:amavis /etc/amavis/conf.d/50-user ;
service clamav-daemon restart ;
service amavis restart ;
service spamassassin restart ;
systemctl enable spamassassin ;
Den letzten Befehl "grep "^\s*DatabaseCustomURL" /etc/clamav/freshclam.conf || echo "" schenken wir uns jetzt mal. Das kannst du später noch über Konfiguration -> Antivirus Scanner -> Zusätzliche Virensignaturen -> auf Standard setzen -> Speichern
2 Möglichkeit)
Noch einmal eine frische Neuinstallation durchführen.
Tschius wrote: Mon 18. Jul 2022, 08:40 inet 192.168.1.114 netmask 255.255.255.0 broadcast 192.168.1.255
Die Adresse wird nicht gerouted, wie ist der Server von aussen erreichbar?
Tschius
Post by Tschius »
ad Möglichkeit 1)
hmm ... das will auch nicht
root@server07:~# su - amavis -s /bin/bash -c 'razor-admin -create' ;
root@server07:~# su - amavis -s /bin/bash -c 'razor-admin -register'usermod -aG amavis clamav ;
su: Ungültige Option -- a
Try 'su --help' for more information.
ad Möglichkeit 2)
das wird schon langweilig, denn das System habe ich bereits 4 mal frisch aufgesetzt.
Jetzt habe ich mal Debian 10.10 (statt 11.4) aufgesetzt - da bekomme ich denselben Fehler raus?!
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/junk.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/jurlbl.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/phish.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/rogue.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/sanesecurity.ftm
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/sigwhitelist.ign2
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/scam.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/spamimg.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/spamattach.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/blurl.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/foxhole_generic.cdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/foxhole_filename.cdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/malwarehash.hsb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/hackingteam.hsb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_malware.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_malware_links.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_extended_malware.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow.attachments.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/winnow_bad_cw.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_cracked_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_malware_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_phishing_URL.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/bofhland_malware_attach.hdb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/porcupine.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/phishtank.ndb
  DatabaseCustomURL https://ftp.swin.edu.au/sanesecurity/porcupine.hsb
  DatabaseCustomURL https://urlhaus.abuse.ch/downloads/urlhaus.ndb
Du musst diesen Server kontaktieren können: discovery.razor.cloudmark.com auf Port 2703 (= Das ist quasi das, was in diesem Step "su - amavis -s /bin/bash -c 'razor-admin -create'" passiert)
Habe eben übrigens mehrere Male problemlos KeyHelp installiert, also die Server von Razor sind erreichbar.
Das sind 2 getrennt auszuführende Befehle:
Re: Installationsfehler "Email protection error"  [GELÖST]
Ist da vielleicht noch irgendeine Firewall dazwischen, die Port 2703 tcp ausgehend blockiert?
Tschius
Post by Tschius »
Ahhh
:o :o :o
Der ausgehenden Port 2703 ist gesperrt. Bei uns sind nur die üblichen Ports freigeschalten (wie 80, 443 usw).
Ich habe jetzt die ganze Mühle neu installiert und mit meinem Testnetzwerk (da ist fast nichts geblockt) verbunden - da hat es funktioniert!
Ich bin nicht auf die Idee gekommen, dass von einem Nicht-HTTPS-Port etwas geladen wird (und daher von der FW geblockt wird).
Vielen Dank!
