Fail2ban default version
Tony20
Post by Tony20 »
Hello, before, I was having fail2ban problems. so I deleted it and did the install again, now Keyhelp have changed the way it work,
but my version does not get update with keyhelp. there a way to fix this so I can get the default version of Fail2ban that come with Keyhelp?
The fail2ban version was install from Ubuntu 20.04
BasHeijermans
Re: Fail2ban default version
Post by BasHeijermans »
Check the logs, it will tell you what went wrong.
In my opinion it doesn't start because of missing logs in jails that can't be read.
Run this, should show something simmular:
service fail2ban status
● fail2ban.service - Fail2Ban Service
     Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-07-18 09:34:36 CEST; 6 days ago
       Docs: man:fail2ban(1)
   Main PID: 150161 (fail2ban-server)
      Tasks: 7 (limit: 38072)
     Memory: 14.8M
     CGroup: /system.slice/fail2ban.service
             └─150161 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
jul 18 09:34:36 sprintweb.be systemd[1]: fail2ban.service: Succeeded.
jul 18 09:34:36 sprintweb.be systemd[1]: Stopped Fail2Ban Service.
jul 18 09:34:36 sprintweb.be systemd[1]: Starting Fail2Ban Service...
jul 18 09:34:37 sprintweb.be fail2ban-server[150161]: Server ready
jul 18 09:34:36 sprintweb.be systemd[1]: Started Fail2Ban Service.
If it fails it will also tell you why.
KeyHelp can't do anything if the deamon won't start.
Greetings Bas.
And to answer your question: KeyHelp installs the Fail2Ban version, which is the default for the particular operating system version.
In the case of Ubuntu 20.04 - it is currently Fail2Ban 0.11.1.
Tony20
Post by Tony20 »
Hello Alexander! is there a way for me to install it and make sure when the KeyHelp Panel get updated is also get update?
This would be the installation commands:
apt-get install -y fail2ban ;
cp /home/keyhelp/www/keyhelp/install/templates/fail2ban/jail.d/keyhelp.local /etc/fail2ban/jail.d/keyhelp.local ;
cp /home/keyhelp/www/keyhelp/install/templates/fail2ban/filter.d/keyhelp-phpmyadmin.conf /etc/fail2ban/filter.d/keyhelp-phpmyadmin.conf ;
chown keyhelp:keyhelp /etc/fail2ban/jail.d/keyhelp.local ;
service fail2ban restart ;
If it still won't work, we would need more input, error messages etc.
BasHeijermans
You may want to send him the default configs that KeyHelp and Fail2ban use.
Then restart fail2ban and see if it works.
Delete entire /etc/fail2ban and replace it with yours.
Greetings Bas.
I did, see the "cp" commands.
